Need vacuum layout for b18 in 91CRX SI....
Old Feb 21, 2003 | 10:17 AM
DsMWookie's Avatar
Default Need vacuum layout for b18 in 91CRX SI....
I have the b18 in and running but the lines are all messed up and its getting bout 8mpg and throwing a map sensor code....I know the lines are all mixed up so any help would be great...
Old Feb 21, 2003 | 10:34 AM
slowpokesi's Avatar
Default Re: Need vacuum layout for b18 in 91CRX SI.... (forward_motion_crx)
heres one from a b16a, not sure if it will help
http://texas.clubsi.com/brandon/crx/swap/b16a.zip
Old Feb 21, 2003 | 12:27 PM
Flexmyrex's Avatar
Default Re: Need vacuum layout for b18 in 91CRX SI.... (slowpokesi)
ls has more lines than b16, i dont know if you can see where the small vacuum lines are routed but here is the pic http://filebox.vt.edu/users/ssteinbe.../rexengine.jpg
ill try to take closer pics
Old Jul 8, 2004 | 06:43 PM
KaoticSnow's Avatar
Default Re: Need vacuum layout for b18 in 91CRX SI.... (Flexmyrex)
talk about bringing a thread back from the dead,
anyway I could use a diagram for my swap. I have a '91 LS in my '89 CRX Si. still need to get the vacume lines all in and could use the help of a diagram anyone know of one?
Old Jul 8, 2004 | 07:56 PM
DohcVtecCrx's Avatar
Default Re: Need vacuum layout for b18 in 91CRX SI.... (KaoticSnow)
map runs off tb everything else runs off vac IE manifold
Old Jul 8, 2004 | 08:12 PM
KaoticSnow's Avatar
Default Re: Need vacuum layout for b18 in 91CRX SI.... (DohcVtecCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcVtecCrx &raquo;</TD></TR><TR><TD CLASS="quote">map runs off tb everything else runs off vac IE manifold</TD></TR></TABLE>thx I'm workin on it now. if I have more questions I'll pm
Old Jul 8, 2004 | 08:16 PM
kylefakesi-r's Avatar
look at the underside of any integra hood...there is your answer.
Old Jul 8, 2004 | 09:23 PM
KaoticSnow's Avatar
Default Re: Need vacuum layout for b18 in 91CRX SI.... (kylefakesi-r)
to bad I don't have a integra hood to look at. anyone have a pic?
Old Jul 8, 2004 | 11:40 PM
Hybridcrx469's Avatar
Here is a great link for b16a vac lines http://b16a.honda-perf.org/Tech/vacuum.jpg. Now of course the crx dosent have the pressure cut-off valve. so i ran thew hose from my pressure regulator to the back of the intake manifold and i dont havce any problems
Old Jul 8, 2004 | 11:44 PM
KaoticSnow's Avatar
Default Re: Need vacuum layout for b18 in 91CRX SI.... (Hybridcrx469)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybridcrx469 &raquo;</TD></TR><TR><TD CLASS="quote">Here is a great link for b16a vac lines http://b16a.honda-perf.org/Tech/vacuum.jpg. Now of course the crx dosent have the pressure cut-off valve. so i ran thew hose from my pressure regulator to the back of the intake manifold and i dont havce any problems</TD></TR></TABLE>
nice that is exactly what I was looking for thanks a million
Old Jul 8, 2004 | 11:56 PM
Rywire's Avatar
heres a better 1 http://www.geocities.com/droppedcrxsi/vacuum1.htm
Old Jul 9, 2004 | 12:05 AM
KaoticSnow's Avatar
Default Re: Need vacuum layout for b18 in 91CRX SI.... (droppedcrxsi)
sweet, I'm guessing there's no diff between the b16 and b18 correct?
Old Jul 9, 2004 | 12:16 AM
Rywire's Avatar
What b18? a,b, or c?
Old Jul 9, 2004 | 12:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">heres a better 1 http://www.geocities.com/droppedcrxsi/vacuum1.htm</TD></TR></TABLE> I think i've seen that one before but the purge cut-off vac line isnt supposed to be going into that area. that person who made that drawing was using a pressure regulator cut-off valve! which the crx doesnt have. at least my DX didnt
KaoticSnow's Avatar
lol, yea that would have been a good thing to state, its a b18a all thats left is the vacume lines and a few small stuff
Old Jul 9, 2004 | 12:32 AM
Damn it would be nice to have saved for the B18
WOW, i was just checkin out your website. Now thats a project!
Good luck man
How about some under the hood shots?
Modified by Hybridcrx469 at 9:42 AM 7/9/2004
Old Jul 9, 2004 | 12:50 AM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybridcrx469 &raquo;</TD></TR><TR><TD CLASS="quote"> I think i've seen that one before but the purge cut-off vac line isnt supposed to be going into that area. that person who made that drawing was using a pressure regulator cut-off valve! which the crx doesnt have. at least my DX didnt </TD></TR></TABLE>
Whatever man, I made that chart, and for my 89 crx si, it worked perfect. I passed cali smog with flying colors. Ryan
Old Jul 9, 2004 | 12:57 AM
KaoticSnow's Avatar
thanks, the engine is in the car now, let me see If I can find my engine shots befor I droped in the engine. I have been trying to locate my digi cam for some time. anyway I have the pix on my 35mm I just need to get it developed.
Si-Samuri
11
Jul 14, 2009 09:52 AM
civicflow
16
Jun 7, 2007 10:50 AM
KillerBTeg
Jan 10, 2005 05:40 PM
crx1856
Aug 18, 2003 10:55 AM
B20zvtecek
May 1, 2002 07:45 PM
