can you re-use your valve cover gasket?
they're only like $11.00 new.
But yeah, if it's a new gasket, and it isn't torn, or hardened, then you can try it.
Worse case scenario is it leaks, and you have to take the valve cover off then replace it.
Always be sure to check the little "O-ring" ones at the bottom. If they leak, your spark plug holes will fill up with oil.
Shaguar47
May 28, 2007 08:47 AM
miksew
13
Oct 20, 2006 05:48 PM
Qwikrex
Nov 18, 2002 02:13 PM
