block guard
Old Feb 21, 2003 | 09:23 AM
rrei's Avatar
Default block guard
would a h series block guard fit a f22b1 or b2, i think the h series is for the 97 up h22
Old Feb 21, 2003 | 01:01 PM
niedejb's Avatar
Default Re: block guard (rrei)
I have no idea. Curious though.
Old Feb 22, 2003 | 01:37 PM
KTeller8's Avatar
not sure, but what i ve read and talked to a few guys that are doing my block work. is that you should make sure you even need it
like i have a 92-96 h22, he said it pointless cause the deck is even. they are meant for 97+h22 that are step decked and a bit lower.. just something to think bout
Old Feb 22, 2003 | 05:05 PM
blackfrohatch's Avatar
Default Re: block guard (KTeller8)
i didnt think f22s or h22s were open deck blocks.....
but if they are i wouldnt get a blockgard i would get the block posted or sleeved...blockgard restrict coolant flow....and the place were u need the coolant the most at the top by the combustion chamber the coolant wont touch because the blockgard will be welded in there.
those little holes wont provide enough coolant to the head....get it posted if anything. or sleeved if u have the cash
Old Feb 22, 2003 | 11:02 PM
paul9luap's Avatar
Default Re: block guard (blackfrohatch)
h22s and f22s are open deck, h23s are closed....
I feel retarted, can somebody explain the difference between a block guard and resleeving the block?
Old Feb 23, 2003 | 04:43 PM
rrei's Avatar
Default Re: block guard (paul9luap)
ok rpm quoted me 1200 to resleeve the block with goldeneagle sleeves and 550 for arias pistons and 475 for eagle rods. now does eagle make rods ofr the f22b1 or h23a since they r the same or are they trying to sell h22 rods with custom price pistons ffrom arias. what did u pay for resleeving niedjb(sp?)
Old Feb 23, 2003 | 05:55 PM
rrei's Avatar
paul9luap here https://honda-tech.com/zerothread?id=319182
[Modified by rrei, 2:56 AM 2/24/2003]
Old Feb 23, 2003 | 09:49 PM
KTeller8's Avatar
getting mine resleeved for about 450
the options after is goign to cost me
Old Feb 24, 2003 | 01:52 AM
niedejb's Avatar
No eagles for F22b1. I didnt want to mess with the rod/stroke ratio by doing what you mentioned.
I sent GE the block and the pistons and it was $1100 for sleeve, bore, hone, and shipping ($50 each way)
Old Feb 24, 2003 | 04:54 AM
Stew Pidasso's Avatar
I thought the H22A1s were closed deck, correct???
Old Feb 24, 2003 | 05:58 AM
carolinaACCORD's Avatar
Default Re: block guard (Stew Pidasso)
correctimundo, the H22A4's were open deck.
93(Civic)EG6
Nov 8, 2006 08:48 AM
redlude94
Oct 14, 2005 07:45 AM
JDMCRX
Feb 2, 2005 11:45 AM
acr91
Apr 6, 2004 05:20 PM
