Better gear ratios
Old Feb 20, 2003 | 08:43 PM
GirlyGS-R's Avatar
Default Better gear ratios
What's the difference in gear ratios between the ZC and SI tranny's? Will it be worth it to switch out my Si tranny for a ZC one? From a 89' rex.
Old Feb 20, 2003 | 08:48 PM
Louie B.'s Avatar
Default Re: Better gear ratios (GirlyGS-R)
ZC has better 1-4 gears, but Si has a better 5th and final drive.
Plus if you put a ZC tranny in you have to change the axles to accomidate the Intermediate shaft, it's a better axle set up (less torque steer) but more work/$ involved.
if you have the skills or $$ for a shop to do it, take the 1-4 gears out of the ZC and put them into the Si tranny.
if you don't want to crack open any cases, I'd stick with the Si tranny.
edit: here's the numbers:
Si ZC
1st 3.25 3.25
2nd 1.894 1.944
3rd 1.259 1.346
4th 0.937 1.033
5th 0.771 0.878
final 4.25 3.888
[Modified by thumpu77, 10:05 PM 2/20/2003]
Old Feb 20, 2003 | 09:06 PM
GirlyGS-R's Avatar
Default Re: Better gear ratios (thumpu77)
Thanx for the info!
LoneStarCRX
Mar 4, 2007 12:24 PM
QuarterMileMaster
Aug 26, 2004 10:59 AM
B18C5-EH2
44
Jul 6, 2004 04:54 PM
davens
Aug 24, 2003 03:08 AM
dRuNk-dRiVer
Feb 17, 2003 07:50 PM
