spoon cams
Old Feb 20, 2003 | 06:52 PM
jansenrw's Avatar
Default spoon cams
Just chasing after info on spoon camshafts. What are the advantages over stock ITR camshafts? Also if anyone has a spoon head (i.e. valves, valve springs and cam gears and cams) what are they Rev limiting to ? Is 9100 rpm ok?
Old Feb 20, 2003 | 06:55 PM
Reid's Avatar
Global Moderator
Default Re: spoon cams (jansenrw)
There's no point in buying Spoon valves.
Also if you want mild cams, get Toda Spec A's.
The Spoon cams aren't worth the time and effort.
Old Feb 21, 2003 | 09:35 AM
AJ PwR's Avatar
Spoon cams has more duration and lift over ITR cams which is more mid-high rpm power. It doesn't require valvetrain upgrades and no problem revving to 9k. Spoon cams are not made for big power gains (lot less stress to valvetrain/timing belt), they try to increase the driveability and to remain the longivity of the engine.Leading the max. potential of the B18C5 with having other stock components in the ITR.
Best results, Spoon cams + gears and reprogrammed ECU or Hondata.
Good luck
[Modified by AJ PwR, 10:38 AM 2/21/2003]
Old Feb 21, 2003 | 09:50 AM
Larkin W.'s Avatar
Default Re: spoon cams (AJ PwR)
Some guy is selling spoon cams on ebay for $650 buy it now price.
Just an FYI and he has a whole lot in stock
Also has lots of good feedback so sounds reliable.
Same guy is selling a lot of other spoon stuff for awesome prices
[Modified by EbboyPSi, 12:51 PM 2/21/2003]
Old Feb 21, 2003 | 10:00 AM
MK Ultra's Avatar
You'd get more bang for the buck if you bought a JUN 2 intake cam.
Old Feb 21, 2003 | 10:08 AM
azn98R's Avatar
Default Re: spoon cams (MK Ultra)
That's what I was thinking... assuming you have a ITR.
[Modified by azn98R, 2:09 PM 2/21/2003]
Old Feb 21, 2003 | 02:45 PM
jansenrw's Avatar
Default Re: spoon cams (azn98R)
Thanks guys... much appreciated...
I was just considering upgrading my spoon cams to toda spec B. Where can I find detailed info about the spoon cam i.e. spec sheets to dial in the cams? Would love to do a comparison to Toda B's.
Jansen
Old Mar 9, 2005 | 07:17 AM
JDM97dc2R's Avatar
what will be the advantage of putting the jun 2 intake cam? what are the gains? do i need to adjust the sproket?
Old Mar 9, 2005 | 07:41 AM
cruzersi99's Avatar
Default Re: spoon cams (JDM97dc2R)
Way back in the day Mike K tried a JUN II intake cam / ITR exhaust cam combo with pretty good results.. I think you can still find the thread in the archive.
Old Mar 9, 2005 | 08:31 AM
da'ee's Avatar
Stock ITR cams
INTAKE lift - 11.5 mm, duration 243 @1mm
EXHAUST lift - 10.5mm, duration 235 @1mm
Jun II specs
INTAKE lift - 12.0 mm, duration 267 @ 1mm
EXHAUST lift - 10.9 mm, duration 265 @ 1mm
Spoon cam specs
INTAKE lift - 11.53 mm, duration 256 @1mm
EXHAUST lift - 11.13 mm, duration 245 @1mm
Toda B specs
INTAKE lift - 12 mm, duration 255 @1mm
EXHAUST lift - 12mm, duration 245 @1mm
Cam specs taken from http://www.team-integra.net
The Jun 2 and Spoon cams are in the same boat in terms of their cam specs and gains that you will see. The Toda B's are in a totally different ball park, your going to have to do extensive work in order to run the B's properly. The spoon/jun cams are good for a little over 200whp with a 8500 redline. The B's are good for 220 whp with a 9000 redline.
Old Mar 9, 2005 | 03:57 PM
SpoogenJay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJ PwR &raquo;</TD></TR><TR><TD CLASS="quote">Spoon cams has more duration and lift over ITR cams which is more mid-high rpm power. It doesn't require valvetrain upgrades and no problem revving to 9k. Spoon cams are not made for big power gains (lot less stress to valvetrain/timing belt), they try to increase the driveability and to remain the longivity of the engine.Leading the max. potential of the B18C5 with having other stock components in the ITR.
Good luck
[Modified by AJ PwR, 10:38 AM 2/21/2003]</TD></TR></TABLE>
I was always wondering what was so special about spoon cams.. thanks for info AJ.
I recently picked up Spoon cams and gears so.. still trying to figure out what else i need for my R rebuild. i guess only thing now is that reprogrammed ECU. oh by the way, AJ how much is a Spoon headgasket? is it still 115.38? cuz if it is im in need of one.
REAL TIME
Aug 19, 2014 05:06 PM
boy_hapon
Aug 22, 2005 08:16 PM
Drag-On
Oct 17, 2002 12:46 AM
capcon83
Aug 7, 2002 03:35 AM
cruzersi99
Aug 7, 2001 06:28 PM
