spark knock/pinging
Old Feb 20, 2003 | 05:09 PM
_Endless_'s Avatar
Default spark knock/pinging
my mom drives a '98 honda CRV A/T so EVERY part is bone stock. the problem is, it is pinging/knocking like hell recently.
i've tried using high octane gasoline(97 octane) and i've also changed the spark plugs but still the knocking is still there. it starts knocking/pinging between 1800-2000 rpm and becomes louder as i step on the gas.
i like to know what caused it to knock/ping suddenly? somebody mentioned that i should retard the timing, but i think that's only a band-aid solution since the timing is also stock spec, as i've said the car is bone stock.
if i retard the timing, driveability will surely be affected. does all car starts to knock with age? what can i do to stop this without altering any stock settings? will using a fuel injector cleaner help, maybe the injectors are dirty? any ideas? it is very annoying.
any help will be appreciated.
Old Feb 20, 2003 | 05:53 PM
slomofo's Avatar
GDD Member
Default Re: spark knock/pinging (_Endless_)
Don't know your answer, but don't use fuel injector cleaner or any additives to gas that's already good cuz they will burn out your O2 sensors.
Old Feb 20, 2003 | 06:35 PM
_Endless_'s Avatar
Default Re: spark knock/pinging (slomofo)
i don't think we have an o2 sensor on our crv's here. our SiR here doesn't come with an o2 sensor.
anymore?
Old Feb 20, 2003 | 09:50 PM
tominos's Avatar
no o2? you sure? prolly down by the cat. have you switched gas lately? maybe timing is off spec, did you check?
Old Feb 21, 2003 | 01:49 AM
_Endless_'s Avatar
Default Re: spark knock/pinging (tominos)
yup on our SiR here, absolutely 101% sure there's no o2. on the CRV, i haven't look but i'm 90% sure.
i haven't check timing, but could timing just go out of spec over age??
hrs-parker
Nov 13, 2008 10:58 AM
garyc17
May 6, 2007 08:41 AM
hondasport2000
May 17, 2004 01:29 PM
RTW DC2R
Nov 12, 2002 03:04 PM
initial-d
Nov 26, 2001 07:52 PM
