does gsr throttle fit d series intake manifold?
Old Feb 20, 2003 | 03:59 PM
Ignitecivic's Avatar
Default does gsr throttle fit d series intake manifold?
i was wondering does the gsr throttle fit a d series sohc vtec intake manifold. and does it required anything else. or it dont work at all
Old Feb 20, 2003 | 04:01 PM
TypRice's Avatar
Default Re: does gsr throttle fit d series intake manifold? (Ignitecivic)
yes!
Old Feb 20, 2003 | 04:03 PM
zCivic's Avatar
Default Re: does gsr throttle fit d series intake manifold? (TypRice)
bolt and go
Old Feb 20, 2003 | 04:09 PM
Default Re: does gsr throttle fit d series intake manifold? (zCivic)
does it do any good when i bolt this on. thanks alot for the commend, just making sure. wat year gsr throttle or any year?
Old Feb 20, 2003 | 04:44 PM
zCivic's Avatar
I know 94-00 not sure about the 92-93's. you can also use a B18B, H22A's CTR all are 60mm or ITR is 62mm. I forgot you may want to port match the mani just because your going from a 56mm to a 60mm. I know it works on a Y8 just to make sure does your T/B ordoes your mani have a funky coolant thingy on it. If its on the manifold I must retact my answer to no because the coolant thing is in the way
[Modified by zCivic, 8:46 PM 2/20/2003]
Old Feb 20, 2003 | 06:34 PM
tominos's Avatar
not gonna do a whole lot, if you don't have any crazy mods done to the engine, but better throttle response the h22's have 62mm tb's i think.
Old Feb 20, 2003 | 06:39 PM
zCivic's Avatar
Default Re: does gsr throttle fit d series intake manifold? (tominos)
See heard 2 different stories. My friend sold me one he said it was from a H22 and its not 62mm its only 60. It has a tube for the map sensor and also a tube where it goes to the charcoal canistor. Its set up like older teg/b16's. Was told it was a H22a though anybody ever seen a h22 t/b and can verify it for me??
Old Feb 20, 2003 | 06:55 PM
1.8Tities's Avatar
I'm using a 91 LS teg tb into my d16y8 intake manifold
rice is nice
Jun 22, 2008 07:48 PM
92hatchy_7
Apr 24, 2005 03:17 PM
Vera
Nov 22, 2003 09:17 PM
CRX Si
Oct 7, 2003 11:18 AM
dxcivic
Feb 17, 2003 03:56 PM
