What is that noise?
Old Feb 20, 2003 | 02:37 PM
Full Race EG's Avatar
Default What is that noise?
I have a 1994 GSR. The other day I raced a brand new GT Mustang and when I went to shift into forth my RPM's shot to about 9500. Now In 1st and second gear I hear this raspy noise. It sound like the heat shield rattling but it is only in those gears. The car runs fine but just makes some weird noises. Do you think that I will be ok or should I pull it apart? Thank You in Advnce.
Old Feb 20, 2003 | 05:46 PM
Rory Breaker's Avatar
Default Re: What is that noise? (IntegraLStuner)
I think you should check your valve clearances ASAP. Hopefully you just knocked them WAY out of adjustment, and none of them are bent.
Old Feb 20, 2003 | 05:49 PM
Default Re: What is that noise? (newgsrdriver)
They tap real loud in 1st and 2nd. Maybe i got lucky and just need an adjustment.
[Modified by IntegraLStuner, 6:58 PM 2/20/2003]
Old Feb 21, 2003 | 05:20 AM
JimBlake's Avatar
Measure your compression. Hope for the best...
Old Feb 21, 2003 | 09:24 AM
Default Re: What is that noise? (JimBlake)
Thanks, I will check them out.
Old Feb 21, 2003 | 12:11 PM
civic91's Avatar
how do you check the valve clearance?
Old Feb 23, 2003 | 09:31 PM
nardeezy's Avatar
Default Re: What is that noise? (civic91)
Get a Haynes Repair Manual, it'll explain how to adjust the valves
Old Feb 23, 2003 | 10:12 PM
IWishIWasRich's Avatar
Default Re: What is that noise? (nardeezy)
just take it to the dealership, its like 50-60 bucks
Old Feb 24, 2003 | 06:47 AM
Default Re: What is that noise? (IWishIWasRich)
Or do it yourself for free....
Old Feb 24, 2003 | 09:04 AM
Eva01's Avatar
Here is a link: valve adjustment
iamthefollower
Apr 23, 2012 04:07 PM
curtie94
Jan 7, 2012 05:32 PM
B20BV
Dec 14, 2007 11:55 PM
hatchfreak92
Dec 2, 2004 08:27 PM
BryanS
Sep 25, 2001 10:46 AM
