is this normal? comptech exhaust install *pic*
Old Feb 20, 2003 | 02:29 PM
sjteg's Avatar
Default is this normal? comptech exhaust install *pic*
is it just me or is something not normal about my exhaust? the resonator hangs really low and i scrape it all the time. One guy mentioned my S looking pipe might be the wrong way. Also notice how my muffler is tilted. Please help, i cant stand the constant scraping.
thanks.
[Modified by sjteg, 11:30 PM 2/20/2003]
Old Feb 20, 2003 | 02:39 PM
XjoEnX's Avatar
Default Re: is this normal? comptech exhaust install *pic* (sjteg)
did u install it yourself? could be the exhaust hangers... it doesnt look backwards to me
Old Feb 20, 2003 | 02:43 PM
sjteg's Avatar
Default Re: is this normal? comptech exhaust install *pic* (XjoEnX)
i had a shop install because i had to get the piping extended.
Old Feb 20, 2003 | 02:56 PM
emr88's Avatar
Looks like they forgot to connect the hanger or something.
[Modified by emr88, 3:58 PM 2/20/2003]
Old Feb 20, 2003 | 02:58 PM
neo1z's Avatar
Default Re: is this normal? comptech exhaust install *pic* (emr88)
Agreed -- Someone definitely forgot a hanger. Comptech typically fits perfectly.
Old Feb 20, 2003 | 03:03 PM
Jolf's Avatar
Default Re: is this normal? comptech exhaust install *pic* (neo1z)
Had to get the piping extended? Sounds like that's probably the root of the problem. Why did it need to be extended and perhaps they didn't weld it up straight.
Tim
Old Feb 20, 2003 | 03:09 PM
sjteg's Avatar
Default Re: is this normal? comptech exhaust install *pic* (Jolf)
the exhaust was originally for a ls so i had to get it extended a bit to fit my 98 gsr. I remember at the shop when the resonator was pushed up by the guy everything looked perfect.
Old Feb 20, 2003 | 03:10 PM
DeadLock23's Avatar
well actully I dont think it has much to do with welding. I have the same problem and my setup is for my LS so it should be fine. But the resonator sits a little lower.
I used the same rubber hanger as I had stock. I dont know why this is but I know I have the same problem and the scraping is annoying when going into driveways.
Perhaps the old hangers (stock ones) are worn out, and "sag" more then they should.
I even tried to use a clamp to hold it to the height shield above it, although it was a pretty good way of solving the problem, it shortly began to rattle, so I havent worked out a solution since. but the clamp had to go.
[Modified by DeadLock23, 7:12 PM 2/20/2003]
Old Feb 20, 2003 | 03:14 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: is this normal? comptech exhaust install *pic* (DeadLock23)
When a shop was cutting the heat shields off my stock piping, they cut off the hangers right below the shifter for some reason, then welded them back on. Now my resonator hangs lower than normal and it scrapes on the slightest of inclines.
[Modified by PatrickGSR94, 6:15 PM 2/20/2003]
Old Feb 20, 2003 | 03:31 PM
sjteg's Avatar
Default Re: is this normal? comptech exhaust install *pic* (PatrickGSR94)
looks like i'll have to live with it
Old Feb 20, 2003 | 03:40 PM
RuskeR's Avatar
Maybe, replace the old hangers?
Old Feb 20, 2003 | 03:42 PM
DeadLock23's Avatar
hey Patrick, do you have a comptech?
why did the shop cut the heatshield?
Old Feb 20, 2003 | 03:44 PM
sjteg's Avatar
Default Re: is this normal? comptech exhaust install *pic* (RuskeR)
how much work would it be to replace the old hangers? Do you mean the rubber peices?
Old Feb 20, 2003 | 03:55 PM
Community Builder
nah I have stock exhaust... they cut the heat shields off trying to get rid of the rattle that turned out to be my manifold.
Old Feb 20, 2003 | 03:59 PM
ebelp's Avatar
That's weird. I was able to remove all of my heat shield that was under the car by unbolting it.
Old Feb 20, 2003 | 04:03 PM
sjteg's Avatar
Default Re: is this normal? comptech exhaust install *pic* (ebelp)
was just looking over the exhaust pic and i noticed that the C-pipe has a hanger. Could that be my problem?
Old Feb 20, 2003 | 04:05 PM
ebelp's Avatar
Most definitely.
Old Feb 20, 2003 | 04:24 PM
DeadLock23's Avatar
so what exactly are you pointing at? if it has a hanger it's most likely hanging isnt it?
so why is it so low? anyone with a comptech system who doesnt have this problem? maybe we can shed some light on this
Old Feb 20, 2003 | 04:29 PM
xero-cool's Avatar
definitely go look under the car and see if they missed any hangers.
You can try zip ties on the rubber thingy's at least that is what SCC did (sport compact car) as a initial solution and get new rubber hangers if they look like they are sagging.
Old Feb 20, 2003 | 05:08 PM
sjteg's Avatar
This picture might show it a little better. The hanger faces the back of the car.
Old Feb 20, 2003 | 05:09 PM
sjteg's Avatar
Default Re: is this normal? comptech exhaust install *pic* (xero-cool)
zip ties? how would i do that? got any pics? If anyone has a comptech exhaust, can you please post a underbody pic of your car. It'd help out alot.
Old Feb 20, 2003 | 06:24 PM
sjteg's Avatar
Old Feb 20, 2003 | 07:24 PM
UnionCity LS's Avatar
same **** happened to my greddy exahust...it was off a 4door..alil too long...and what happened was it needed to be cut...and yeah my resignator scrapes like a bitch...over speed bumps...when it was dropped about1.75"-2" so now its raised to1.5" sux...
Old Feb 20, 2003 | 07:26 PM
sjteg's Avatar
Default Re: is this normal? comptech exhaust install *pic* (UnionCity LS)
damn the last thing i want to do is raise my car... too much work.
Old Feb 20, 2003 | 08:25 PM
DeadLock23's Avatar
As far as I know, all the hangers on my setup are being used. Whether it is the rubber things themselves I am unsure of. I will try to investigate, I know a few people with the exhaust, I'll see how their setup is.
Maybe some new rubber will solve the problem, but its too cold for me to mess around with it now, I'll wait until Spring.
