new bearing = new hub?
Old Feb 20, 2003 | 01:08 PM
Old Skool's Avatar
Default new bearing = new hub?
i have to replace my d.s. wheel bearing and im not sure if i should go ahead and replace the hub as well. since they are separate components i figure the hub should be fine, but then again mybe not. its a $115 piece and i sure could afford not to buy it. So what do you guys think?
Old Feb 20, 2003 | 02:24 PM
RedGSR's Avatar
Default Re: new bearing = new hub? (Old Skool)
for most honda cars, the hub and bearing are one piece. I am not sure what year accord you have. I just got mine replaced on a 00 Accord. The part was $100 from dealer. You can get the part at hondaautomotiveparts.com for $70 or so.
Old Feb 20, 2003 | 02:33 PM
b18bEG's Avatar
Default Re: new bearing = new hub? (RedGSR)
on my accord its 2 pieces, its not too hard to replace
Old Feb 20, 2003 | 03:08 PM
Old Skool's Avatar
Default Re: new bearing = new hub? (h22akrd)
yeah, i replaced mine already when i first did my swap, but i didnt get custom axles made that i needed a long time a go so my bearing is fucked..so is it necessary for me to replace the hub as well, or is it a-g?
Old Feb 20, 2003 | 04:14 PM
TypeSH's Avatar
im wondering that too, does the hub need to be replaced? or can just the bearings be replaced?
Old Feb 20, 2003 | 05:41 PM
Old Skool's Avatar
Default Re: new bearing = new hub? (TypeSH)
I was talking to one of my buddies who works at a parts counter at the local honda dealer...he's pretty knowledgable and he said it doens have to be replaced most of the time..but im just trying to get a second opinion. Im not too worried about it so im sure you dont have to be either..but it would be a good idea to make sure.
i mean 115 bux is 115 bux, ya kno?
[Modified by Old Skool, 2:41 AM 2/21/2003]
Old Feb 21, 2003 | 12:01 AM
TypeSH's Avatar
dont forget thats $120/side (according to hondaautomotiveparts),
bearings are only 60-70 or so per side.
Old Feb 21, 2003 | 10:38 AM
Old Skool's Avatar
yeah, i only need one side though cuz its all kindsa fucked up
anyhoo..is anyone going to answer my question?
Old Sep 24, 2004 | 07:56 AM
accordion's Avatar
I guess it's kinda late at this point, but I kept my hub when I replaced the bearing, and so far it is fine.
(That's on a '95 LX, no ABS).
Old Sep 24, 2004 | 08:09 AM
TouringAccord's Avatar
H-T Order of Merit
No, you don't need to replace your hub unless you did something that could have damaged it. Otherwise, you don't normally need to replace your hub. You do need a press to press the old bearing off a the new one on. What year Accord is this for anyway?
When I did my brake job I bought new bearings as well. I took everything to a machine shop and had them take everything apart and press it all together. I had a 95 with hub-over-rotor and it's a PITA to do. So thats why I paid a shop 25 a side to do mine. Anyways, when the bearings were replaced I just had the same hubs pressed into the new bearings and the hub face turned so the rotor would mount nice and clean to it.
Old Sep 24, 2004 | 08:20 AM
accordion's Avatar
Default Re: new bearing = new hub? (TouringAccord)
I got them pulled off/pressed on too. It would have been easy to DIY, except for that damn inner race of the bearing. I used a claw puller to get most of the bearing off, but the inner race sits flush to the hub, so there is no place to wedge a tool to get it off. Drilling the race is out of question, that steel is harder than my drill bits I've no idea what the guy in the shop did to pull it...
Old Sep 24, 2004 | 09:41 AM
H-T Order of Merit
Default Re: new bearing = new hub? (accordion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordion &raquo;</TD></TR><TR><TD CLASS="quote"> I've no idea what the guy in the shop did to pull it...</TD></TR></TABLE>
there is a tool used to get under that inner race. Look in the Helms manual and it shows you what it looks like and how to use it. But to use it you need a press.
charliecd5
Feb 12, 2015 06:01 PM
gnx547
Jun 1, 2009 06:47 PM
Bnjmn
Sep 20, 2005 03:43 PM
Saintor
Jun 17, 2004 10:18 AM
Old Skool
Feb 21, 2003 12:13 PM
