95 accord front wheel bearing and hub replacement
so ive decided too replace the hub assembly with new bearing, too not have too deal with pressing new bearings in, are there any methods anyone could throw my way too make this as painless as possible? Thanks guys!
Re: 95 accord front wheel bearing and hub replacement
You can use a slide-hammer to extract the hub from the bearing, but going back in will require a press.
[EDIT] Misread. The way the hub assembly is built, from what I've gathered through photos, is that after the 4 bolts have been removed there is still a metal lip of the hub assembly that is friction-fit into the knuckle and may still need a slide hammer to remove, and then a dead-blow hammer or similar to reinstall.
To remove the hub unit from the knuckle:
you can usually get the hub unit loose from the knuckle by removing the four bolts that hold it on, replacing them with four longer bolts that leave at least a half inch gap after being threaded in 6-10 turns (or the same thread distance that the originals tighten with) and tap them with a hammer in a crisscross pattern, little by little until it comes loose. clean out any rust and apply some anti-seize to the knuckle before you put the new one in. thread the original bolts in and with 1/4 to 1/2 turn each, one after the other, use them to draw the bearing up to the knuckle.
I've used this method successfully for years without issue. If you pay attention and work carefully it should work for you also.
To get new bearings installed:
either buy the hub shaft and bearings both new or get some used hub units from the junk yard and have new bearings installed. carry everything to a nearby shop and have them press the bearings onto your new or used hub shafts. then all you need to do is install them on the vehicle as a pre-assembled unit.
When you press the hub off the bearing it leaves the inner race on the shaft of the hub. The only way I have found (and the local shop as well) is to grind down the bearing race enough that a coal chisel can crack the race. There is simply no way for a puller to grab the race.
I've considered trying to heat the inner ring and chill the shaft (with dry ice) just to see if it would work... but haven't yet.
I usually pull whole knuckle. And put it in a strong vice. Loosen the hub bolts...but dont totally remove them. Then use a big hammer( ihave a short three pound sledge that works great)...hit the bolt heads..and that will press out the bearing. Thats the easiest way i have found...with no presses or pullers needed. Plus you wont screw up the threads on the wheel studs, cause knuckle is in vice.
Bnjmn
09-20-2005 03:43 PM
