Replacement Suspension Parts
Where can I find replacement front suspension parts for the 5th gen Accord? (94 ex vtec coupe to be exact)
I'm looking for higher performance replacement parts for things like the steering knuckle, control arms, ball joints, strut fork, spring hat, etc.
good luck looking for them. I'm not even sure if there is any performance control arms, ball joints, fork, trailing arm...etc for Integra (which has a much larger performance market).
How can a ball joint be high performance? Honda ball joints seem to hold up pretty well (the boots is another story) you can find performance bushings tho... Steering knuckles same thing, it's a ball joint as long as it does it's job i.e. doesn't come apart and no play, then that's as good as it gets....
Try the "www.accordstore.com" I am about to buy some polys for my car they also have a complete set that has ball joint covers...also do you know what size diameter the stock swaybar in the front of a MY94 EX is?
[Modified by MY94Accord, 4:37 AM 2/21/2003]
i got a energy suspension master set that comes with almost everything for the front end, the thing is you need some of the things pressed in. the master set does come with boots for ball joints. i got a suspension techniques front sway bar as well (havent got to try it out yet). there are parts out there, search for them. summitracing.com has some good prices on some stuff, and the shipping is free.
masospaghetti
Mar 26, 2015 09:45 AM
