just got a turbo timer and dont know how to hook it up
i just bought a greddy turbo timer and i dont know how to hook it up can anyone help me i bought it from my friend and he said i need to splice wires because he never used it its brand new its ment for like a supra or something that comes with turbo so its got clip on the end to just plug in and its not going to work so if anyone can help let me know
Solder the main harness of the TT to the ignition wires like below:
Pics here: (You could have done a simple google search FYI)
http://importnut.net/turbotimer.htm
Ive done a couple cars like this and it works great......
Brian
Brian
What do you mean it still won't turn on?
If you wire up the main harness (the red green and blue wires) just like in that pic, as well as grounding the little black wire to the frame, it should work perfectly. It's not necessary to do the ebrake and speed sensor hookup to have a functioning turbo timer......
Brian
Brian
If you wired it up exactly like in the pic, it should work.....
Get a voltmeter and test to see that the wires are all getting the correct signals and that each wire does what it's supposed to (constant power has voltage all the time, acc on has voltage when key goes to accessory on mode, and ignition on has voltage when the car is turned on and running).....
If the voltages are correct and it's wired like in those pics, then you have a faulty turbo timer....did you buy it used?
Brian
Brian
Some of that bs might be in here http://www.geocities.com/chipman_13/clippings.html
i got the turbo timer installed and now i dont work it turns on and all but i messed with the settings and now it wont keep the car on when i turn the car off does anyone know how to work a greddy turbo timer oh and by the way i appreciate all the help
Have you tried hitting the power button? I hate to ask a dumb question. Also, do you have it grounded on a good spot? If you do not have it grounded properly, it will not work. The ground wire is not present in that pic.
I'm the one that put that article with the pic toghter. I did a '95 GSR and a '99 Si. I've talked to people that said it's the same wiring that would be used on 4th gen civics as well as 2nd gen integras.
