Yet another DPFI-MPFI Question..
Old Feb 20, 2003 | 09:15 AM
Malgerus's Avatar
Default Yet another DPFI-MPFI Question..
Raene and I are doing an MPFI swap so I can use my B16A in my 88 DX. There is an extra plug on the harness and it plugs into something on the D15B2 that the B16A doesn't have! Anyone know what this is? It plugs in to some sort of cylinder right behind the DPFI throttle body!
Old Feb 20, 2003 | 09:20 AM
Hcivic88's Avatar
Default Re: Yet another DPFI-MPFI Question.. (Mr. S)
I believe there is a plug that you dont end up using when you switch to mpfi. I'm not positive about this, but I remember hearing it from someone on this forum.
Also, if someone that has done the swap could have a quick look over the write up i've done for DPFI-MPFI and let me know if my info is correct, i'd really appriciate it. thanks <A HREF="http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
" TARGET="_blank">http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
</a>
Old Feb 20, 2003 | 10:21 AM
Redline130's Avatar
When I swapped a B18A into my DX, there was an extra plug on the harness. I think it was a round one (like the IAT) with 2 or 3 wires. My friend who did the wiring just cut it off.
Old Feb 20, 2003 | 10:25 AM
Hondasaurs's Avatar
You will have these 3 plugs left over when you are done. Its not needed for the MPFI.
The other two plugs are for the fuel injectors on the DX.
Old Feb 20, 2003 | 11:46 AM
4drEF's Avatar
Keyboard Humorist
It's for the tandem vavle for the DPFI system. You don't use that.
Old Feb 20, 2003 | 12:28 PM
Urban Business
Guest
Posts: n/a
Default Re: Yet another DPFI-MPFI Question.. (4drEF)
yes and the other 2 injector plugs get cut off those wires are used 1 for each injector, remain 2 goto the resistor box if obd0
Old Feb 21, 2003 | 08:38 AM
Malgerus's Avatar
Default Re: Yet another DPFI-MPFI Question.. (limoZeen)
Awesome! Thanks guys!
x707saelee88
Jul 16, 2007 07:32 AM
user 72830283
49
Sep 23, 2006 11:25 AM
SomeDude56
Mar 16, 2006 03:15 AM
ZCVTEC-SOHC
19
Jul 24, 2003 11:15 AM
TravisEK
Jun 9, 2003 12:24 PM
