gears grinding
Old Feb 19, 2003 | 11:35 PM
R-1303's Avatar
Default gears grinding
can a weak pressure plate cause a grinding in the tranny?
Old Feb 20, 2003 | 12:00 AM
SoCal ITR's Avatar
Default Re: gears grinding (R-1303)
Like when you shift?
Old Feb 20, 2003 | 04:48 AM
AssPenny's Avatar
Default Re: gears grinding (SoCal ITR)
There would be a slight possibility that it will dude to the pressure plate not fully releasing the clutch, thus you are basicaly trying to shift with out using your clutch.
Old Feb 20, 2003 | 08:55 AM
92TypeR's Avatar
FSAE
Default Re: gears grinding (AssPenny)
If the pressure plate is not engaging the clutch all the way or the flywheel is worn down too much, those are both contributors to grinding gears.
But the major factor is bad driving.
BM Syncromesh. Go buy it and replace your fluid, should help a lot. Be ready to fork out some $$ however!
Old Feb 20, 2003 | 08:58 AM
Reid's Avatar
Global Moderator
If your syncros are just beginning to go bad, it may seem as though the clutch is not engaging fully due to the fact that the gears only grind slightly.
Old Feb 20, 2003 | 11:08 AM
R-1303's Avatar
Default Re: gears grinding (Reid)
does anyone know of aftermarket syncroes?? i'm sick of the shitty honda ones..those drag honda's must use somethin...
Old Feb 20, 2003 | 11:09 AM
mr2's Avatar
mr2
those drag hondas are stock dude! hehe
Old Feb 20, 2003 | 06:36 PM
R-1303's Avatar
Default Re: gears grinding (turbo sw20)
suure david, so i guess i have to stick with the pos honda ones?
Old Feb 20, 2003 | 07:04 PM
TypeR 599's Avatar
Default Re: gears grinding (92TypeR)
BM Syncromesh.
is this an aftermarket syncro?
Old Feb 20, 2003 | 07:09 PM
Reid's Avatar
Global Moderator
Default Re: gears grinding (TypeR 599)
It's an additive.
Old Feb 20, 2003 | 07:12 PM
hungsteR's Avatar
How is it grinding, when you first put it into gear or at the engaement point? What's the severity level of the grinding?
Old Feb 20, 2003 | 07:13 PM
D's Avatar
D
Honda synchros are not pieces of ****, it's the drivers that don't know what the **** they're doing.
Old Feb 21, 2003 | 12:39 PM
R-1303's Avatar
Default Re: gears grinding (D)
really??? sorry i race my type R! but trust me i know what i'm doing ask the people who seen my ride...just stay on the east coast buddy
Old Feb 21, 2003 | 12:40 PM
Reid's Avatar
Global Moderator
D is right.
There is nothing wrong with Honda syncros.
None of my B series cars have a problem with syncros.
Old Feb 21, 2003 | 12:55 PM
SoCal ITR's Avatar
I'm thinking D might actually race from time to time....
Old Feb 21, 2003 | 01:22 PM
XR4racer's Avatar
Yeah D! He races his type R man.. just ask the people who have seen his car.
as Catch22 would say..... WHEEEEE!
Old Feb 21, 2003 | 01:28 PM
nfn15037's Avatar
I would have to agree. I have 110k miles on my tranny and no bad syncros yet. I change my tranny fluid every 10-15k, so that mught help. There is nothing wrong with Honda syncros.
Old Feb 21, 2003 | 01:29 PM
D's Avatar
D
Default Re: gears grinding (XR4racer)
oh, my bad, i never have any idea what i'm talking about.
[qute]as Catch22 would say..... WHEEEEE! [/quote]
lol....
Old Feb 21, 2003 | 01:31 PM
AssPenny's Avatar
Default Re: gears grinding (nfn15037)
Well I must say, my syncros suck... All 3 of them went out Could have been cause I ran it for a day or 2 with no tranny fluid, but i'm not sure
Craig - Who is looking to have a tranny party March 28th in So FL
Old Feb 21, 2003 | 01:33 PM
XR4racer's Avatar
Or it could have been the NAWSS in-between shifts, right?
WHEEEE!
Old Feb 21, 2003 | 02:29 PM
i 4's Avatar
i 4
A weak pressure plate could cause grinding yes ..a while back a friend misshifted(b/c he cant drive for his life) and he told me that he was having trouble getting into gears ( so i thought, you just cant drive for your life) so i went to drive his car and he was right... I pulled the tranny and the pressure plate had cracked, so i put in a CM clutch and it was fixed.
So for people that have miss shifted badly , and have been having problems with shifting , check the clutch for damage. AND LEARN TO DRIVE.
[Modified by i 4, 6:29 PM 2/21/2003]
95Sedan
Jan 9, 2014 11:23 AM
o0Jash0o
Oct 27, 2006 01:33 AM
zad5
Jun 7, 2004 09:12 PM
It's Blue
Oct 18, 2002 04:27 PM
