Looking for a certain oil line fitting (turbo oil feed)
IM gonna run my oil feed from the oil pressure sender tap on the block & skip the tee (just let the oil pressure sender hang there, its not like it does anything anyways)
i have a -4an oil feed line so i'll need a 1/8bpst male to -4an male fitting, correct??
i've looked thru http://www.anplumbing.com & cant find one.
also, should i get aluminum or steel fittings?
MikeMAN
Jul 2, 2002 09:25 PM
