Radiator question?
while i was workin on my car, i noticed that there were 2 small rubber plugs that were on of 2 metal things sticking out of the radiator. one was on each side of drain plug. one of the rubber plugs was ripped. i was just wondering if these were critical to the radiator or the cooling system. anyone have any ideas??
thanks
thanks
those things are what keeps the radiator from vibrating, if is ripped and is not bad, it's ok, if is really bad the go to a junkyard and buy it, is nothing to serious, the radiator sit in those.
see it
the rubber goes there:
and it fits on those two holes
see it
then you have an AUTO car, those are the trannies passages for cooling, yeah, change it cuz if you break it then you would lose tranny fluid and possibly blew the tranny
Hey man, you either have the auto accord radiator, or an aftermarket one that is made for use in either auto or manual...mine does not need caps on the auto hook-ups but you might want to get them just for good measure...that is, if you have a manual
weird, I noticed mine has those thingies too. It is a non-oem part. Probably like stated earlier, they can be used on the manual or auto cars.
Do not use the auto tranny portion of the radiator as a oil cooler, the fluids are not the same, they have different viscositys.
That's how it is with Aftermarket radiators. They build one radiator for both the manual and auto (Unless it's a radiator built for total drag racing, then it's only manual). If you have a manual, just leave that thing alone and don't worry about it.... at least that's what I did and I've been fine.
Secondly, have you seen the inside of that passages in a radiator? is just a straigh line with a pipe of about 1 cm (i'm metric guys), so it won't mather.
As for the ones that had this in their radiator and your car is manual, WEIRD, i pulled my radiator out and it didn't have them, mine is a 95 LX manual
yz125rider21
15
Jan 7, 2008 11:42 PM
