Will a FPR act in the same way as APEXi SAFC??????
Old Feb 19, 2003 | 06:43 PM
integraautox's Avatar
Default Will a FPR act in the same way as APEXi SAFC??????
I might be running a cam set up on my integra and I was wondering if a AEM Fuel Pressure Regulator/gauge (or another brand) do the same thing as the apexi safc? I know with the SAFC you can adjust the air flow thoughout the RPM range and the FPR you have a set PSI but will the FPR help with a lopy idle and allow me to run a cam set up safely once tuned by a dyno shop.
Old Feb 19, 2003 | 06:50 PM
spettinger's Avatar
Default Re: Will a FPR act in the same way as APEXi SAFC?????? (integraautox)
the afc will be a much better way to tune the car. a fuel pressure regulator will just up the pressure all the time, not necessarily a good thing. the motor will not always need higher fuel pressure all the time, and you will be wasting gas, and hurting performance by running too rich. get the afc.
Old Feb 19, 2003 | 08:36 PM
Casey's Avatar
Default Re: Will a FPR act in the same way as APEXi SAFC?????? (2ndhandCRX)
an safc is good for taking fuel away. but if you try and correct +11% or more (adding fuel) the ecu wont read it and will throw a cel. For better results use fpr and safc. for best results go hondata
Old Feb 19, 2003 | 08:49 PM
spun Vtec's Avatar
Default Re: Will a FPR act in the same way as APEXi SAFC?????? (Casey)
i will be running both the vafc and fpr and also bigger injectors
..nice casey i like the location woo lives on..
Old Feb 19, 2003 | 08:59 PM
Casey's Avatar
Default Re: Will a FPR act in the same way as APEXi SAFC?????? (4gsicivichatch)
i heard that they made tshirts too haha
91integraLSVTEC
16
Mar 7, 2004 07:16 AM
toooslow
Jun 13, 2003 04:06 PM
JeremyL
Mar 12, 2003 03:54 AM
1.8T_EG
Sep 17, 2002 07:29 AM
LSCivic
11
Sep 25, 2001 08:19 AM
