Strange Sound, Help PLZ! (Video Inide)
Old Feb 19, 2003 | 06:15 PM
TurBoXBirD16's Avatar
Default Strange Sound, Help PLZ! (Video Inide)
I just took a video of my car, and there is a strange sound, it sounds like air leaking, but i checked my charge pipes, no leak
here is the video, turn up your speakers, then you will hear it !
thanks !
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D
Oh, there was a problem before, refer to this post:
https://honda-tech.com/zerothread?id=416834
Old Feb 19, 2003 | 06:19 PM
turbod16y8's Avatar
Default Re: Strange Sound, Help PLZ! (TurBoXBirD16)
are you talking about the deep whistling sound? kinda like a hummm?
[Modified by turbod16y8, 7:19 PM 2/19/2003]
Old Feb 19, 2003 | 07:09 PM
Default Re: Strange Sound, Help PLZ! (turbod16y8)
yea... that sound... like air going through...
try turning up your speakers, you will hear it clearly !
thank you !
Old Feb 19, 2003 | 07:51 PM
Tinker219's Avatar
Either Im not hearing anything, or you have some awesome turbo noise
my t3 was louder than ****...you heard the turbo spool over the exhaust, and that was sweet...
if that isnt the noise you are hearing, than sorry for wasting yours and everyone elses time....
Old Feb 19, 2003 | 07:57 PM
Default Re: Strange Sound, Help PLZ! (Tinker219)
no.. that's not the turbo's noise for sure....
coz it wasn't like that before....
turn up your speakers, you can hear it..
i am sure that ain't turbo noise!
Old Feb 19, 2003 | 08:04 PM
bryan305's Avatar
which part? the part where it's not spooling smoothly, or the blow off between shifts?
Old Feb 19, 2003 | 08:06 PM
Tinker219's Avatar
Default Re: Strange Sound, Help PLZ! (bryan305)
ya, which part? by the way, I had my speakers cranked and all I heard was AAAAAAAAAGHHHHHHHHHHHHHGUUUUUUuuuu distortion sucks
Old Feb 19, 2003 | 08:08 PM
swrdply400mrelay's Avatar
Are you talking about the noise that sounds like you have a window open or something?
Old Feb 19, 2003 | 08:52 PM
Default Re: Strange Sound, Help PLZ! (swrdply400mrelay)
yes i think so...
You guys should listen very carefully when I am in FOURTH gear...
I was stepping and releasing my gas, and you can clearly hear that sound..
fourth gear was the obvious gear that shows that sound....
you can hear that when I let off the gas, the sound disappears...
Old Feb 19, 2003 | 10:04 PM
LshatchTurbo's Avatar
New User
damn is your car haunted
Old Feb 20, 2003 | 01:35 AM
MiraiZ's Avatar
Default Re: Strange Sound, Help PLZ! (lshatchturbo)
Okay...I had to listen to this on my home PC with the huge speakers to hear it....I had this problem a loooong time ago when I had my CR-X. My car sounded like it was getting a lot of wind resistance, expecially on the freeway...It wasn't coming form the engine bay either. It sound like, as someone described earlier, my windows were open, or my doors weren't shut all the way.
What it turned out to be on my car was, somehow the gap between the fender panel and the door panel widened a bit causing it to take on a lot of wind resistance. So when the wind hit it, the air collected in the gap and it sounded as if my doors were open.
Check to see if all the panels, bumper is on straight...
Old Feb 20, 2003 | 04:49 AM
Tinker219's Avatar
I had to go on my PC too...um...
its something to do with letting off the gas...it could be many things.
1.) Drivetrain movement resulting in the engine bucking around in the engine bay along with the exhaust and shift linkages(charge lines too, IC) resulting in some nasty chafing...
2.) your BOV is screwed up big time...but I thought I could cleanly hear the BOV...
Old Feb 20, 2003 | 06:57 AM
b18cTurbo's Avatar
you have a transmission bering failure for sure
b18cTurbo's Avatar
Default Re: Strange Sound, Help PLZ! (C5turbo)
i had this problem experience before
