Getting new clutch installed this weekend, can the OEM Throwout bearing be used again?
Old Feb 19, 2003 | 06:03 PM
MikeMAN's Avatar
Default Getting new clutch installed this weekend, can the OEM Throwout bearing be used again?
heya, ever since my b16a2 was swapped..the clutch has always slipped (i know its dumb but it would never chirp even 2nd) so I have pieced together a turbo kit and bought a nice clutch (ACT HD PP w/ 6puck racing disc )
so my question, is when the clutch is off..can the mechanic that is doing the clutch install (i don't have the tools or jacks i should say, or the time really ) use the OEM throw out bearing with the new clutch? or could I get one from a dealer for cheap? (i need a clutch alignment tool, what kinda/size/model do i get?? are they car specific?)
thanks in advance!,
mike
[Modified by MikeMAN, 8:46 PM 2/20/2003]
Old Feb 19, 2003 | 06:39 PM
IN VTEC's Avatar
Default Re: Getting new clutch installed this weekend, can the OEM Throwout bearing be used again? (MikeMAN)
If you bought the whole package from ACT, it should include the clutch alignment tool for your car. Altho, there are times when you can opt not to buy it (ie: Massimo Performance). The tools are spline number- and size-specific.
I always prefer OEM Honda stuff, unless I know it's the same stuff.
Old Feb 19, 2003 | 07:34 PM
MikeMAN's Avatar
Default Re: Getting new clutch installed this weekend, can the OEM Throwout bearing be used again? (IN VTEC)
i am asking would it be okay to use the same bearing over?
the clutch alignment tool didn't come with because the box was opened, (bought from mike from motormatrix.com)
thanks,
mike
Old Feb 19, 2003 | 09:04 PM
Passaudi1.8t's Avatar
New User
It would be a good idea just to use a new t/o bearing. Who knows, the one you have now might go bad say 3 months after the install... then you are stuck with the hassle of dropping the tranny and having to replace it. A new t/o bearing shouldn't cost more than $40 from the dealership. As for the clutch alignment tool, you can get them at any auto parts store for a couple of bucks. Good luck with the install.
Old Feb 19, 2003 | 09:07 PM
salbaje's Avatar
use the new t/o bearing to save you problems later on
Old Feb 20, 2003 | 04:55 PM
KingDsi's Avatar
Default Re: Getting new clutch installed this weekend, can the OEM Throwout bearing be used again? (salbaje)
New TO bearing...
Old Feb 20, 2003 | 05:19 PM
raene's Avatar
Default Re: Getting new clutch installed this weekend, can the OEM Throwout bearing be used again? (vtecivic
Definitely replace the bearing. They're cheap insurance... would you like to have to pull the transmission again just to replace that one piddling thing?
Old Feb 20, 2003 | 05:36 PM
integra6650's Avatar
not to nit pick but you said you got the hdss
thats heavy duty plate and a modified streat/strip disk not a 6 puck and if you were doing a 6puck wouldn't you want a xt plate or a max xt plate(just read that this was open box)
i have the alighnment tool if it comes down to it i can send it to you
i would definately replace bearing oem or not a new one would be better
[Modified by integra6650, 9:38 PM 2/20/2003]
Old Feb 20, 2003 | 05:46 PM
MikeMAN's Avatar
Default Re: Getting new clutch installed this weekend, can the OEM Throwout bearing be used again? (integra6
sorry...how about HEAVY DUTY damn nit pickers..i know what i have you pecker
Old Feb 20, 2003 | 06:00 PM
i wasnt trying to be a dick i was trying to help i didn;t want you to put something in your car you didn't want adn i was confused on whether you had a ss or a 6 pk
Old Feb 20, 2003 | 06:36 PM
leadfoot78's Avatar
You can reuse all the old bearings but I or any one who has dropped a tranny before wouldn't recomend it. I fyou got the clutch alredy whats another bearing or two. DO IT RIGHT THE FIRST TIME.
Old Feb 21, 2003 | 07:53 AM
MikeMAN's Avatar
i know buddy, i was just jokin' with ya thanks dude
91grape
15
Feb 11, 2013 10:55 AM
moz92
Transmission & Drivetrain
Apr 4, 2011 06:56 AM
anewfoundkevin
Jul 12, 2010 02:25 AM
Iloveyourhonda92
Aug 24, 2009 12:44 PM
prelude_93vtec
Oct 14, 2007 02:12 AM
