to those with jun 3's--what fuel computers or engine management do you use?
Old Feb 19, 2003 | 05:39 PM
spettinger's Avatar
Default to those with jun 3's--what fuel computers or engine management do you use?
a friend is picking up a hatch with spec3's, would like to hear from those who have tuned them. the jun ecu would obviously be ideal, has anyone tuned them with a hondata?
Old Feb 19, 2003 | 06:05 PM
skunkwhat's Avatar
Default Re: to those with jun 3's--what fuel computers or engine management do you use? (2ndhandCRX)
I have stage two skunks tuned with a hondata
Old Feb 19, 2003 | 06:14 PM
spettinger's Avatar
Default Re: to those with jun 3's--what fuel computers or engine management do you use? (skunkwhat)
what motor and what hondata unit? was it difficult to find good settings? thanks.
Old Feb 19, 2003 | 10:04 PM
H25's Avatar
H25
i run the jun stage 3 cams in the motors i build. and i have dont extensive amount of testing on the track and dyno as well. and i have found the current program i have for a p28, and p72 seems to run the fastest with the juns. i noticed a big difference in top end power especially after 8 thousand rpm . if anyone needs a ecu programed just let me know.
max-
Old Feb 20, 2003 | 09:18 AM
ping83's Avatar
Default Re: to those with jun 3's--what fuel computers or engine management do you use? (LuckyRacing)
i have a b18c and i am going with the jun 3's, skundk2 intake manifold, and the regular i/h/e. i also have a zex nitrous kit on the car (50 shot). what ecu would u recommend me goin with and how is the nitrous going to effect this. thanks, matt
Old Feb 20, 2003 | 11:11 AM
TimoneX's Avatar
New User
Default Re: to those with jun 3's--what fuel computers or engine management do you use? (ping83)
Definately get Hondata.
Old Feb 21, 2003 | 10:04 AM
spettinger's Avatar
Default Re: to those with jun 3's--what fuel computers or engine management do you use? (TimoneX)
i believe the ecu in the car is a jdm b16 computer, possible a P30?? is this a correct ecu code?
Old Feb 21, 2003 | 10:13 AM
YumVTEC's Avatar
p30 = obd1 i believe... if your car is an 88-91 then it's most likely obd0 (pr3, pw0) unless you converted it to obd1.
Old Feb 21, 2003 | 11:17 AM
TimoneX's Avatar
New User
Default Re: to those with jun 3's--what fuel computers or engine management do you use? (YumVTEC)
I think the P30 is an OBDI Vtec ECU from a Del Sol.
Old Feb 21, 2003 | 11:26 AM
junya16's Avatar
i'm runnin the jun 3's with the skunk2 p28 and a vafc, cams pull like a motha after they're tuned. oh yea and if you don't have the right header you will need it cause you'll lose a lot of power with just like a regular dc. that's my 2 cents
Old Feb 22, 2003 | 07:56 AM
advanracing62's Avatar
Default Re: to those with jun 3's--what fuel computers or engine management do you use? (junya16)
JUN III cams, tuned with Hondata in a P28. I've just got a basic JUN map in now... the dyno was busy when I tuned so I just got it to pull good and left it. There's more power to be had, but it'll take time.
junbb1
Dec 15, 2003 08:38 AM
junbb1
Dec 14, 2003 08:35 PM
92TypeR
Apr 22, 2002 10:59 PM
Xb16aX
Jan 18, 2002 12:34 AM
itr1236
Sep 25, 2001 08:01 PM
