22 mpg b16 + $2.20 gas = not going anywhere for awhile with my daily driver
Old Feb 19, 2003 | 05:31 PM
CLICC916's Avatar
Default 22 mpg b16 + $2.20 gas = not going anywhere for awhile with my daily driver
damn...the b16 has horrible gas mileage...does everyone else get the same mpg? and 22 mpg is on surface streets AND highway...the worse part is, something's wrong with my ecu and/or oil pressure sensor...
btw, does anyone around the sac area have a b16 ecu (obd 0) i can borrow to see if i have a faulty ecu?
Old Feb 19, 2003 | 05:36 PM
customx_'s Avatar
New User
Default Re: 22 mpg b16 + $2.20 gas = not going anywhere for awhile with my daily driver (CLICC916)
i have a pr3 thats in my car...
Old Feb 19, 2003 | 05:55 PM
SteveeeO's Avatar
u get 22 mpg on a b16, I get 22 mpg on a d15b2... don't feel bad
Old Feb 19, 2003 | 05:56 PM
civicwagonman's Avatar
Default Re: 22 mpg b16 + $2.20 gas = not going anywhere for awhile with my daily driver (SteveeeO)
man that sucks. I get 19 out of my awd turbo wagon. don't drive it much. my hf gets about 42. maybe your o2 sensor is gone? i would try a factory honda one, much more acurate than the bosch crap.
Old Feb 19, 2003 | 07:18 PM
Blaze45's Avatar
Brrraaaap!
Default Re: 22 mpg b16 + $2.20 gas = not going anywhere for awhile with my daily driver (civicwagonman)
Jeez how do you guys drive? Makes me scared to drive my B20 once i get it in. Is it because of the sprited drving or just how you choose to tune your car? Any one else have this happen? What is the typical MPG for a occasionaly hard driven/rev'd B20? anyone?
Blaze
Old Feb 20, 2003 | 10:12 AM
SteveeeO's Avatar
Default Re: 22 mpg b16 + $2.20 gas = not going anywhere for awhile with my daily driver (Blaze45)
i don't drive my car hard at all... I think something is messed up on it causing it to get such bad gas milage - I have to sorta step on it sometimes to make it move (we all know the power d15 has !)
Old Feb 20, 2003 | 11:25 AM
big pete's Avatar
i got about 30mpg on my b16 with i/h/e thats freeway/city driving...crusing on the freeway at about 80mph(5k rpm)
Old Feb 20, 2003 | 12:01 PM
ElementMotor's Avatar
Default Re: 22 mpg b16 + $2.20 gas = not going anywhere for awhile with my daily driver (big pete)
I got about 225 miles to a tank in my 88 crx with B16 and PR3 ecu, and that was on a good tank....
Old Feb 20, 2003 | 12:17 PM
jdmWONG's Avatar
Default Re: 22 mpg b16 + $2.20 gas = not going anywhere for awhile with my daily driver (EF8 ownz u)
the best ive ever done was 36 mpg in the b16 rex, all highway miles. i averaged 29 mpg, there has got to be somthing wrong with your car. or maybe im just lucky
[Modified by Blow'N'CRX, 1:20 PM 2/20/2003]
Old Feb 20, 2003 | 12:25 PM
jdmhondageek's Avatar
Default Re: 22 mpg b16 + $2.20 gas = not going anywhere for awhile with my daily driver (Blow'N'CRX)
i dont think this will help much. but i get 55.4 kmpg ( sorry JDM cluster ) with my B20vtec with 290cc prelude SH injectors. It is also set to 13.8 air to fuel raio. measured on a tech-edge wide band O2 sensor. I also get 450kmpg per tank btw the car is a 91 SI.
Old Feb 20, 2003 | 01:28 PM
CLICC916's Avatar
Default Re: 22 mpg b16 + $2.20 gas = not going anywhere for awhile with my daily driver (Agent_Smith)
yeah i might have a messed up O2 sensor or something...but i'm too lazy to get the one between my exhaust manifold and block....looks too hard. 22 mpg is with 80mph freeway cruises and normal takeoffs and such....
hey agent_smith....can i meet you up somewhere and borrow your ecu for a test run or two?
Old Feb 20, 2003 | 02:10 PM
b16_madman's Avatar
w/my j1 trans and not grandma like driving i get like 17mpg...in the streets!...or 225 b4 i fill her up on prem. again...suck it up wuss. You gotta pay to play....or since i just have one "running" car...ill pay to play....
Old Feb 20, 2003 | 05:08 PM
raene's Avatar
Me too. I hate the freeway RPM
Old Feb 20, 2003 | 05:18 PM
MrTodd's Avatar
Default Re: 22 mpg b16 + $2.20 gas = not going anywhere for awhile with my daily driver (raene)
Heh, that's it? I'm getting 38 MPG now-- city/highway mixed driving. And I'm not babying it either. Even without the VAFC, only running on the low camshaft lobe, I still got about 36 MPG using my PG7 ECU. SOHC VTEC gives you the best gas mileage. IMO, my current setup is in every way better than sticking with my A6. I have much more power, it weighs the same, and I get better gas mileage! What more could I ask for?? <---Turbo!
Old Feb 20, 2003 | 06:00 PM
raene's Avatar
Default Re: 22 mpg b16 + $2.20 gas = not going anywhere for awhile with my daily driver (MrTodd)
Why would that be...?
It's called OBDI and taller gears
And yes I am envious in that respect
[Modified by raene, 7:01 PM 2/20/2003]
Old Feb 20, 2003 | 06:08 PM
Blaze45's Avatar
Brrraaaap!
but the B16 can handle the freeway revs. Its got the best r/s ratio. 1.75. perfect.
But HEY who likes to cruse @ 5k? not me, but look at it this way, real close to VTEC> lol
Blaze
Old Feb 20, 2003 | 07:00 PM
kranked91dx's Avatar
my p28 run in default mode, trowing me constantly a code 41, damn,
mine do someting like 22 on normal driving, on hard driving it's horible, I see gas comming out of the tail pipe!
ouch, my wallet!
kranked
Old Feb 20, 2003 | 09:03 PM
JRSC EM1's Avatar
My mileage sux too. 22 normally 25 if I can manage to keep my foot out of it. If you go to Burlingame by the SF airport 91 octane is $2.35. Hella sux. I Costco gas stations under $2.00 .
Old Feb 20, 2003 | 09:18 PM
Louie B.'s Avatar
I was getting 25mpg in my d15b1 w/ mpfi swap, changed the O2 sensor (and put a header on) and it kicked up to 29mpg. I've been told in another forum that if obd0 hondas are running below 170 deg, they stay in "cold mode" which makes them run rich and waste gas. and our cooling systems are so efficient that in weather like most of the country is having right now, our cars never get above 160 or so. the cure: block off 1/2 to 2/3 of the radiator so air can't flow through it. I just did this to mine today and I'm taking a long road trip this weekend (to the HT NW meet in Seattle). I'll let you guys know if it helped any when I get back Sunday night.
Old Feb 21, 2003 | 09:36 PM
Default Re: 22 mpg b16 + $2.20 gas = not going anywhere for awhile with my daily driver (thumpu77)
yep,
thinking seriously about the rad thing,
it seem it's not a bad Idea,
keep me up on this please,
see ya
Kranked
Old Feb 21, 2003 | 09:59 PM
FullMetalJacket's Avatar
Default Re: 22 mpg b16 + $2.20 gas = not going anywhere for awhile with my daily driver (kranked91dx)
if your that concerned about gas Id suggest a LS trans for its longer gears..but i bet ur car could be in need of a tune up..just because you have more hp doesnt mean you loose that much gas mileage..I have a V8 car with 3 speed auto and it gets 17mpg and makes 330 whp
Old Feb 21, 2003 | 11:32 PM
escocrx's Avatar
i suggest making more money. or being less stingy. :>
takes 12 to 15 bux AT MOST @2bux a gallon to fill my tank. it'll do 200+ mpt
b16a+j1 tranny pr3ecu
i usually put octane booster in too. as jdm motor. japan has higher octanes at the pump. so around 20 bux wit booster a fill. no offense. but dayum
Old Feb 21, 2003 | 11:40 PM
crx586's Avatar
i get around 30 MPG... b16, header, CAI, and exhaust... and i drive hard...
Old Feb 22, 2003 | 12:27 AM
crxtreme27's Avatar
Default Re: 22 mpg b16 + $2.20 gas = not going anywhere for awhile with my daily driver (crx586)
i get about 244 miles per tank in my stock 89 Si, and about 230 on my 89 DOHC ZC DX.... they both suck....
Old Feb 22, 2003 | 08:36 AM
b16_madman's Avatar
i just took out one of my 2 rad fans....the really small one.....in front of the exhaust manifold/header....due to clearance issues...runs tiny warmer now...but now just @ the good temp mode....so ok!
