Broken studs on a 98 gsr
Old Feb 19, 2003 | 04:56 PM
sshaikh01's Avatar
Default Broken studs on a 98 gsr
Above pic is just an example.
(i know its not the gsr, it from my 1.5)
The stud which is on the second row, far left. That stud is broken.
I was trying to install DC 4-2-1 header as i was tightening the stud, i heard a snap,
and the dam stud came in my hand.
Any advice what to do now ??
Asad bhai feel free to edit the post.
Old Feb 19, 2003 | 05:04 PM
sytema's Avatar
Default Re: Broken studs on a 98 gsr (sshaikh01)
take it to a machine shop, they would be able to get it off from you
Old Feb 19, 2003 | 05:08 PM
sshaikh01's Avatar
Default Re: Broken studs on a 98 gsr (sytema)
I have a hunch that i have to remove the head, all of the internals, from the head.
Than take it to the machine shop, and they should compress should compress it in there.
Old Feb 19, 2003 | 05:14 PM
Skiller's Avatar
ok he posted this for me.... on the GSR you have two studs on the corners and than bolts for the rest of holes. the stud which broke is the on the side..... not the bolt.
can this be pulled out without removing the head???
any help would be greatle appreciated
Old Feb 19, 2003 | 05:44 PM
IN VTEC's Avatar
Default Re: Broken studs on a 98 gsr (Skiller)
Easiest way might be to just use a pair of vice grips and twist it out.
If it's too tight for the vice grips, use an EZout. But, you'll almost certainly have to remove the head to get enough room to work.
Old Feb 19, 2003 | 05:45 PM
IN VTEC's Avatar
And they aren't pressed in.
Old Feb 19, 2003 | 05:54 PM
sshaikh01's Avatar
Default Re: Broken studs on a 98 gsr (IN VTEC)
So basically do i have to remove the head ??
If i wanna leave it stud like this, would i have major exhuast leaks. i assum i would.
Old Feb 19, 2003 | 05:58 PM
IN VTEC's Avatar
Please re-read what I posted above.
I've seen exhaust manifolds missing that stud and they still sealed just fine. Can't promise you anything tho. Don't try to overtighten the other bolts to compensate tho if you choose to forego putting in a new stud...you'll just get yourself into more trouble.
Old Feb 19, 2003 | 06:21 PM
stnwag0n's Avatar
if part of the broken stud is exposed, screw two nuts onto the expeosed area, then try to unscrew the stud with an open wrench using the nut closer to the head. this should cause the nuts to lock and act as the head of the stud. the stud should come out with no problem
[Modified by turb0accrd, 3:22 AM 2/20/2003]
Old Feb 19, 2003 | 06:34 PM
IN VTEC's Avatar
Default Re: Broken studs on a 98 gsr (turb0accrd)
Really, the first question I should have asked is where did it break off at?
Old Feb 19, 2003 | 07:58 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Same stud broke on my car when I was removing the manifold so I could get the inner heat shield off. That was almost a year ago and I have no exhaust leaks. That same stud breaks on most Integras when a header installation is done.
If you're really intent on getting it out w/o removing the head you could probably remove the front bumper and radiator and fans in order to get a drill bit and screw extractor in there.
[Modified by PatrickGSR94, 10:58 PM 2/19/2003]
phyzJunkieCivic
Aug 23, 2006 06:49 AM
slayersluck
Mar 25, 2006 11:50 PM
Liquidgsr
Mar 7, 2005 09:17 AM
G U E C O
Sep 10, 2003 07:30 PM
