For those with OBDII to OBDI conversions
Old Feb 19, 2003 | 04:25 PM
swrdply400mrelay's Avatar
Default For those with OBDII to OBDI conversions
I just put in an OBDII to OBDI conversion harness with a P28 ECU into my D16Y8. The problem is, I get a CEL number 9, cylinder position sensor. Is this normal? If it is, how do I get rid of it? Or do I have a defective ECU or harness?
Old Feb 19, 2003 | 06:03 PM
Default Re: For those with OBDII to OBDI conversions (swrdply400mrelay)
Ok edit: The CEL was actually a number 19, my fault. Code 19: Lock-up Control Solenoid Open or short in LCS circuit, defective LCS solenoid. We took apart the ECU and it looks virgin. I put it into my friend's car and he got the CEL too. Anyone know how I can fix it?
Old Feb 19, 2003 | 06:06 PM
Tinker219's Avatar
Lock up control selenoid?
Im not sure what that is even...sounds like something for a tranny...
Old Feb 19, 2003 | 06:44 PM
Default Re: For those with OBDII to OBDI conversions (Tinker219)
Hahaha, guess what? You're right. Turns out the part number on my ECU reads:
37820-p28-A52
I was told it's an automatic ECU. A "1" instead of "5" would be a manual.
Jaker's Avatar
What is the part number on your ECU? 37820-P28-XXX. I need to know the XXX part. Sounds like you have an auto ECU. Its pretty easy to change to manual though.
Old Feb 19, 2003 | 07:02 PM
PolosportZ81's Avatar
New User
Default Re: For those with OBDII to OBDI conversions (Jaker)
wait, so if u have an auto ecu, and u wanted a manual ecu, it would be easy to change?? please explain thanks
Old Feb 19, 2003 | 07:39 PM
Default Re: For those with OBDII to OBDI conversions (PolosportZ81)
You should be able to change if you send it in somewhere, now I just gotta find a place.
Old Feb 19, 2003 | 07:52 PM
Tinker219's Avatar
I love being right
actually that was a stab in the dark but cool...almost like it had hair around it...
Old Feb 19, 2003 | 08:09 PM
New User
would it not be easier if u just got a manual one??
Old Feb 19, 2003 | 08:22 PM
Yes but more expensive. They go for around $125, and to send it in to switch it to a manual is a lot less than that. I don't think I can find anyone who wants an auto ECU.
Old Feb 19, 2003 | 09:41 PM
H22coupe's Avatar
Check with B18C-EJ1 on this board. He sells P28's and does programming of them. He was quick to reply to questions from me.
Pistolero281
May 26, 2017 12:44 PM
h0nda n00b
Engine Management and Tuning
Feb 27, 2014 09:13 AM
Quarter Performance
Jul 19, 2010 05:38 PM
CD8coupeSiR
Mar 29, 2007 05:13 PM
Hatchorama
Dec 27, 2006 07:06 PM
