ls/vtec conversion information please
Old Feb 19, 2003 | 02:57 PM
JDM_tib's Avatar
Default ls/vtec conversion information please
My friend have a 92 integra rs and he wants to do a ls/vtec conversion but he doesn't know what he needs to change, so heres his questions:
-Could he use b16a cylinder head?
-What type of head gasket should he use?
-Should i have to change something in the engine block(including piston,rod and crankshaft) and in the tranny?
-Is it cheaper than only swap a complete b16a?
-Theres is other things to change?
Thanks and please excuse my english im from quebec so my english is not perfect.
Old Feb 19, 2003 | 03:05 PM
joe_bocc's Avatar
Default Re: ls/vtec conversion information please (JDM_tib)
yes the B16 head can be used. In fact, it is the most commonly used head for ls/vtec.
The LS gasket should do the trick.
The engine and tranny can remain stock.
yes. it is proably cheaper than doing a full B16 swap because you only have to get the head.
You will need the ECU from a B16 to control the VTEC operation.
[Modified by joe_bocc, 12:11 AM 2/20/2003]
Old Feb 19, 2003 | 03:08 PM
tnbigdawg's Avatar
Default Re: ls/vtec conversion information please (joe_bocc)
correction, use a ls gasket. an ecu with vtec engagement, or a chipped ecu, or a vtec controller.
do a search for more information.....
......that is all.
98IntegraLSNonVtec
60
Feb 28, 2006 04:46 PM
civicswap
Jun 4, 2005 06:44 PM
Wong Wonder
Feb 23, 2003 02:21 PM
migo
Sep 27, 2002 06:38 PM
