Changing CV boot
Hey guys... this is kinda a newbie question. I need to change my cv boot cause its ripped and grease is all over the bottom of the car. Can someone pleeeease give me an idea or step by step instructions on how to change it? What do you need to take out? I want to do this myself so the next time I know how to do it. Thanks for the tips.
Nope. they are like $55 at NAPA and autozone will match that.
If you do go for the boot replacement kits, they'll cost considerably less in parts (about $15 I believe if you can find them). But if you don't clamp the boots to the shaft correctly/tightly, they'll just slip back off. Plus, replacing the boot will take more labor than popping out the old shaft and putting a new one back in.
Unless of course the driver's side shaft is STUCK in the intermediate shaft. Then you'll be better off rebuilding the shaft b/c that joint probably isn't coming loose.
So I suggest locating both a boot replacement kit and a complete shaft. Then first try to pull out the entire driver's side shaft from the intermediate shaft (behind the oil pan). If that doesn't come out with the use of the prybar and some body weight behind it, then leave it in there and just do the boot replacement.
Replacing the axle is also less labor intensive and easier for the less mechanically inclined.
after buying the new axleshaft assemblies...this is what you do.
1. lift front end of car, remove wheels.
2. remove the large center nut (on the rotor) that holds the axle.
3. behind and to the bottom of the rotor, there is a nut on a bolt facing down...remove the locking pin and remove nut.
4. now the fun part... take a hammer and tap the center of the rotor at the axle.
the axle will slide out of the rotor.
5. then follow the axle to find the other end, which connects to the tranny.
6. take a flat head screw driver and hammer...stick the flat head between tranny and base of the axle and tap the screw driver. this should dislodge the axle from the tranny. and remove it.
7. get the new axle..slide base end into the tranny making sure the grooves line up
8. slide other end back into the rotor.
9. reapply the nut on bottom (don't forget the locking pin) and large center nut tap a dent into the center nut lip. (there is an existing dent..you'll see...keeps the nut from loosening) thats it...
email me if any questions.
JCracer723
10
Jan 22, 2004 02:54 PM
