Where do AGX's adjust?
Old Feb 19, 2003 | 11:40 AM
mph6563's Avatar
Default Where do AGX's adjust?
I'm probably about to get a set of AGX's in 92-95 Civic fitment. All the web pages say that the adjuster is "either a **** on the body or a slot in the top." Can anyone tell me which it is for this application? And if it's on the side, can you reach it without removing the wheel? Thanks!
Old Feb 19, 2003 | 11:51 AM
sgT's Avatar
sgT
Default Re: Where do AGX's adjust? (mph6563)
slot on top
Old Feb 19, 2003 | 12:05 PM
mph6563's Avatar
Default Re: Where do AGX's adjust? (sgT)
That's great, thanks!
Old Feb 19, 2003 | 02:26 PM
sslude's Avatar
by on top do you mean that you have to pull the shock off to change the settings? or is it possible to change te setting without pullin off he shock?
Old Feb 19, 2003 | 02:29 PM
Goldfingiz's Avatar
Default Re: Where do AGX's adjust? (sslude)
The shocks stay on. They adjust at the very top of the shock tower, with a flat screwdriver. Just a simple turn and that's it.
Old Feb 20, 2003 | 08:11 AM
delslow94's Avatar
Default Re: Where do AGX's adjust? (Goldfingiz)
the adjustment is on the tip of the shaft. its small like the size of a pea but its there
Old Mar 14, 2003 | 03:26 PM
kay_animation's Avatar
I just installed them. They are on the top of the shock screw. Just pop your hood to get at them. I do have a question though. The selections are 1, 2, 3, and 4. What is softest and what is hardest?
Old Mar 14, 2003 | 04:23 PM
the DR.'s Avatar
Default Re: Where do AGX's adjust? (kay_animation)
there are actually 2 types, i think for a 92-95 the fronts would be 4 way adjustable and the rears would be 8
rears look like this http://www.kyb.com/shocks/agx.html it has the adjuster on the body, and is accessible by reaching through or around the wheel.
the fronts should just have the adjuster on top, 4 being stiffest 1 being softest
BAYxlude88
Dec 15, 2008 03:41 PM
Wsteun
Apr 28, 2008 12:10 PM
Frog
30
Jun 27, 2004 06:25 PM
AndyD
Oct 14, 2003 08:50 AM
