some suggestions please...
Old Feb 19, 2003 | 11:07 AM
XxCarChickxX's Avatar
Default some suggestions please...
what should i get w/550 dollars? I already have a carbon fiber hood, exhaust, springs, wheels, header, and flywheel. I thought of a few things but i wanted to get some suggestions. thanks in advance.
Old Feb 19, 2003 | 11:17 AM
Lewie's Avatar
I'm here for the gangbang!
Default Re: some suggestions please... (XxIntegraGurliexX)
definitely get the new aem cold air intake v2....supposedly get like 15 whp out of it...
Old Feb 19, 2003 | 11:27 AM
cwestin'39's Avatar
Default Re: some suggestions please... (lewie4)
Are you going NA or turbo? You should save up for your turbo, or get stronger internals.
Old Feb 19, 2003 | 11:32 AM
Lewie's Avatar
Default Re: some suggestions please... (cwestin'39)
https://honda-tech.com/zerothread?id=419582
check this thread out....he seems to have the same question as you
hope it helps.
Old Feb 19, 2003 | 11:59 AM
poo flinger
Guest
Posts: n/a
Old Feb 19, 2003 | 12:04 PM
Lewie's Avatar
Default Re: some suggestions please... (I can't believe this ****)
Well then what do you suggest??? For 250 bucks it will get you more horsepower and gas mileage...
Old Feb 19, 2003 | 12:06 PM
B2FiNiTY's Avatar
Shocks Sway bar
Old Feb 19, 2003 | 12:59 PM
OC 335i's Avatar
Do you have an alarm? If no, first get an alarm. Kill switch? If you are looking for something performance-oriented, a set of CTR cams & cam gears would be a good choice. Which brings the question motor do you have? How's your clutch? You can get a clutch.
Are you looking for Aesthetics? You can get a nice lip. Color match your car, if it isn't already.
How about tunes? You have a good stereo? You can get a decent head unit and some speakers...
More info about your car is needed. Pictures would be extremely helpful.
While you're at it, post your pic too.
Old Feb 19, 2003 | 06:03 PM
Default Re: some suggestions please... (B2FiNiTY)
Shocks Sway bar
i actually already have shocks i just forgot puttin it in my post but i think i might save up for getting a turbo. i want some more speed. ill still take suggestions if u have them though, thanks.
Old Feb 19, 2003 | 06:07 PM
silvercivicgrl's Avatar
Id say save your $ for your turbo...have plenty left over just incase you need other thinks (like a bigger fuel pump and whatnot) **** tends to go wrong with turbos alot (I know all about it my bf used to have a boosted lude) It's better to save that money instead of just blowing it on something you might not really want
grandam
32
Dec 11, 2007 05:31 PM
MCHAccordLX
Sep 17, 2006 08:54 AM
25Type-s
Sep 13, 2006 08:47 PM
HondaFool
Jun 8, 2004 07:51 PM
williamdte
May 9, 2004 12:52 AM
