open wastegate?
Old Feb 19, 2003 | 10:15 AM
asianspeed's Avatar
Default open wastegate?
I'm having problems boosting and I think that my wastegate might be open? How can I tell if it is? Should I be able to move the arm? If so, in what direction would be open? I've got a 14b with the stock internal wastegate.
Thanks
Old Feb 19, 2003 | 10:24 AM
r4adkshn1's Avatar
Default Re: open wastegate? (asianspeed)
http://www.vfaq.com/mods/Turbo-rebuild.html
check it out. if your wastegate is open no boost. if it's slightly open, never closed, slow to get boost and max psi.
Old Feb 19, 2003 | 11:21 AM
asianspeed's Avatar
Default Re: open wastegate? (r4adkshn1)
Hey, thanks for the page. Yeah, I just finished installing my turbo and I'm getting no boost, so i think that the wastegate is open. But I wanted to see how I could tell. i'm going go with that picture and compare it to my car. I hope that's the reason, then I can fix it and continue on my quest to boost.
Thanks
Old Feb 19, 2003 | 12:24 PM
civperc's Avatar
yeah it could be your wastegate, but make sure to check all vacuum points, fittings, and piping to be sure
Old Feb 19, 2003 | 12:32 PM
GOLDBERG's Avatar
dude..hahaha
https://honda-tech.com/zerothread?id=419646
Old Feb 19, 2003 | 09:05 PM
asianspeed's Avatar
Default Re: open wastegate? (GOLDBERG)
Yeah dude, I seen that. But I was having my problem before I put a rag on mine. I hope that's the problem. But I couldn't boost at all...not even 1 psi. So I don't think that it's that. I did however remove the actuator arm of the wastegate and the engine rev'd very nicely. I used to not be able to red line at a stop...but now I am. So I'm going to put the 450cc's back in, the resistor box, and the map limiter and remove the rag from the compressor and leave the wastegate off. If I boost, then I'm going to put the wastegate back on. And then see if I still boost. I'll hopefully get all of that done tomorrow.
Thanks
Nermin
Aug 3, 2011 09:22 PM
typexero
Nov 21, 2008 06:48 PM
60-1
Mar 18, 2004 11:30 PM
blu_si
Oct 1, 2002 04:20 PM
