Vtec Pressure and ECT sensors on B18C1...
Old Feb 19, 2003 | 05:56 AM
See Are X's Avatar
Default Vtec Pressure and ECT sensors on B18C1...
Im havin trouble tryin to figure out which on is which. Is the ECT sensor right next to the Vtec solenoid? or is that the Vtec Oil Pressure switch? also, what sensor is the one that is mounted right near the lower radiator hose?
Old Feb 19, 2003 | 05:59 AM
1bad-eg's Avatar
Default Re: Vtec Pressure and ECT sensors on B18C1... (See Are X)
the sensor next to the solenoid is the vtec pressure switch. The ect is located on the thermostat housing. Can you describe the sensor by the lower radiator hose?
Old Feb 19, 2003 | 06:44 AM
See Are X's Avatar
Default Re: Vtec Pressure and ECT sensors on B18C1... (1bad-eg)
[QUOTE]The ect is located on the thermostat housing.QUOTE]
thats what im talking about, i got it now...thanks...
Old Feb 19, 2003 | 08:57 AM
sgT's Avatar
sgT
ECT is actually on the side of the head
the vtec switch is on the side of the solenoid(green plug)
The fan switch is on the thermostat housing
Old Feb 19, 2003 | 09:01 AM
Kataku2K3's Avatar
Default Re: Vtec Pressure and ECT sensors on B18C1... (sgT)
Yup the ECT and ECT gauge are mounted on the distributor end of the head... The ECTSW is mounted on the thermostat housing and controls the radiator fan just as sgT said... Peace
Old Feb 19, 2003 | 05:54 PM
See Are X's Avatar
Default Re: Vtec Pressure and ECT sensors on B18C1... (Kataku2K3)
ok, I just realized I dont have a Vtec oil pressure switch...my friend said I have a vtec solenoid from a ITR cause they dont use the pressure switch
Old Feb 19, 2003 | 05:59 PM
Kataku2K3's Avatar
JDM motor... NOT just cuz it's an ITR... USDM ITR ECU's still look for a VTM signal... Peace
Not2farFromtypeR
Aug 8, 2011 05:00 AM
Jdm John
14
Jun 19, 2011 04:24 PM
smileydub
Jul 3, 2010 07:38 AM
PinkMaggit
Mar 12, 2007 05:43 AM
e2000
14
May 26, 2005 04:31 PM
