changing valve springs and retainers
Old Feb 18, 2003 | 10:53 PM
ITRfaithful's Avatar
Default changing valve springs and retainers
for a B18B, is this relatively easy to do in a garage? any resources i can use on the web?
[Modified by b18newbie, 7:53 AM 2/19/2003]
Old Feb 18, 2003 | 11:13 PM
InevitableRace's Avatar
Default Re: changing valve springs and retainers (b18newbie)
If you have the tools then go for it...
The main things you are going to need is a machine to do a valve job..
A valve spring compresser
Some valve lapping compound
And another machine to resurface the Head...
And a tool to lap the valves in..
and theres other stuff but those are the main things..
-Ross
Old Feb 19, 2003 | 06:35 AM
HEAD's Avatar
actually, it is sort of easy, I think it would take you less time to pull the head off and do it so your not leaning over a car for hours but besides the knowledge of how to do it you'll need your basic hand tools and you'll need a valve spring compressor Snap-on sells one for doing it on the car.good luck! And don't worry you don't have to machine anything.
Old Feb 19, 2003 | 08:50 AM
delslow94's Avatar
Default Re: changing valve springs and retainers (HEAD)
yea no biggie on doing it. i got the snap on along with a few friends and we did like 4 cars in one night. really easy. dont machine anything or lap the valves if your just changing the springs and retainers, its not necessary unless you have a really large amount of miles on your motor. good luck
Old Feb 19, 2003 | 09:10 AM
RAWB's Avatar
Default Re: changing valve springs and retainers (delslow94)
Snap-on sells 2 spring compressors. Both say you can do it with the cylinder head either ON or OFF, but 1 costs $45(looks like a clamp with a **** on the top) and the other $115(comes in a case and has several attachments). Which one did you use? I'm looking to replace my springs and would like to avoid removing the whole head. TIA
Old Feb 19, 2003 | 04:05 PM
HEAD's Avatar
Default Re: changing valve springs and retainers (RAWB)
I would use the one with the attachments, it comes in a red case really easy to use, buy the right tool once and make some money with it doing your buddies cars!
State.of.Prime
Oct 17, 2010 01:43 PM
B18T3T4
Dec 9, 2006 06:29 PM
sleepin91teg
Jun 20, 2004 05:34 AM
SpeedracerS4
Dec 11, 2001 04:37 PM
95gsr
Oct 7, 2001 08:07 PM
