I have an entire 90 Integra LS.. What parts will fit my car?
you could do a complete brake system swap. Larger front discs and rear discs as well. If you wanted, you could swap over the Teg's suspension as well. HTH.
cyber13
http://cyber13.speedhawaii.net
cyber13
u sure you wann do that? my buddy did the same..... get's smoked regardless. That's what ur not hpping for rite..... that's y ur swapping?
just my 2 cents..
just my 2 cents..
If you're swapping in the motor use the axles, and you can shorten the linkage, I don,t know if the brkes would really help, maybenjust the rear if they're disc.
I second that. front disc and rear disc brakes helps alot, especially when your putting a bigger motor in it. swap out the rears with the integra suspension, so you can use higher rate springs from the integra compared to the civics. if you really like your integra, take the dash and graft it in your car! just dont do any taillight and headlight conversion
its cheesy!
its cheesy!
yeah do all that but get a VTEC head and ecu and all those gay parts you beed to do a VTEC head on an LS block. then youll be in mid 14s. quite nice.
Rear brakes work well from the ls, everything you need will be there. Front brakes would be good too, although I wouldn't swap the front suspension because it screws up the geometry up front. I second the ls/vtec, I have a 91 si hb w/ lsvtec, i/e, stock b16a1 head, stock s1 tranny, and I ran high 13's on crappy street tires in FL.
ExclusiveCRX
17
Feb 28, 2007 10:21 AM
esoterEK..
Nov 17, 2005 07:07 PM
