uuuhhh someone broke my drivers side window in front of my house.....
Old Feb 18, 2003 | 09:21 PM
XEF-9X's Avatar
Default uuuhhh someone broke my drivers side window in front of my house.....
****** punks. how hard is it to replace a window????
Old Feb 18, 2003 | 09:35 PM
ZERO COOL's Avatar
New User
Default Re: uuuhhh someone broke my drivers side window in front of my house..... (XEF-8X)
It's pretty easy to replace. You have to pull off your door panel and get a good look on the inside of the door frame. There is two bolts that hold the window in place on the rail, take those off, but keep the screws, you'll need those on the new window. Put the new glass down from the top and line it up with the holes on the rail. This takes some time, you'll have to adjust the rail up and down and back and forth to get it in the right place but it's not hard. Just be patient, it might get a little frustrating, but dont worry, you'll get it.
Old Feb 18, 2003 | 09:36 PM
EG8R's Avatar
Pull the door panel. Crank your window till you see two bolts in the regulator that hold the window in place. It should be farely straight forward....
Old Feb 19, 2003 | 04:18 AM
Patch's Avatar
Default Re: uuuhhh someone broke my drivers side window in front of my house..... (mr. skelly)
It's not bad, it seems impossible if you've never done it before. Go to the junkyard, get a window (Probably 40 bucks, work them down). Take off the door panel. You can see on your new window where it bolts up, so take the bolt out of whats left of your old window. Take a vaccuum cleaner and suck out the glass, have a buddy help you slide the new one down and pop the bolt in. That's it!
Old Feb 19, 2003 | 05:20 AM
XEF-9X's Avatar
thanx guys!
crxaddikt
14
Jun 21, 2011 11:32 AM
acc0rdf22
Oct 8, 2009 12:17 PM
BULL3TPR00F
Aug 15, 2008 08:28 PM
Knightmare69
Apr 24, 2006 09:24 AM
pinoyboy204
Jul 30, 2003 06:17 PM
