what ecu in 95 gsr??? p 28?
Old Feb 18, 2003 | 08:13 PM
95gsr's Avatar
Default what ecu in 95 gsr??? p 28?
I think it's a p28 but you guys might know better what ecu does a 95 gsr have??
thanks
luis
Old Feb 18, 2003 | 08:24 PM
TimoneX's Avatar
New User
Default Re: what ecu in 95 gsr??? p 28? (95gsr)
P72.
Old Feb 18, 2003 | 08:25 PM
jabroni95gsr's Avatar
Default Re: what ecu in 95 gsr??? p 28? (TimoneX)
but if you have serious mods and a skunk mani i would change it for a chipped p28.
Old Feb 18, 2003 | 08:42 PM
TimoneX's Avatar
New User
Default Re: what ecu in 95 gsr??? p 28? (jabroni95gsr)
There's really no point in switching to a P28 from a P72. You can chip your OBDI ECU just fine and the ECU wouldn't know or care if you replaced your stock dual runner manifold with a skunk2 IM. I switched to a P28 to run Hondata, but I had an OBDII ECU. It will give you a CEL if you remove the useless knock sensor however. The P28 would not.
Old Feb 18, 2003 | 08:47 PM
True, but in case he wants to keep the p78 to return to stock, he could either find a chipped p28 in the class pretty easiliy or get an unchipped OBD1 version for about $120, then chip that...either way. Chipping the p78 is fine too, but tuners have just told me that the p28 is more flexible.
Old Feb 18, 2003 | 08:51 PM
threatcon13's Avatar
New User
its a p7TWO meatball. even if you chip the p72 ( ie for hondata) you can return it back to stock spec. thats what i did w/ my p72. no reason for someone w/ a b18c1 to get a p28.
Old Feb 18, 2003 | 09:01 PM
Default Re: what ecu in 95 gsr??? p 28? (Threatcon13)
and chipping it back to spec would cost how much? $125? either way, the $ is the same.
Old Feb 18, 2003 | 09:07 PM
New User
you dont have to chip back to spec for removal of hondata. cost=free.
Old Feb 18, 2003 | 09:15 PM
i didn't even realize we were talking about hondata...oh well. its late, give me a break!
Old Feb 18, 2003 | 09:18 PM
New User
its all good. j/k .
Old Feb 19, 2003 | 01:00 AM
UberTeg's Avatar
to return to stock, burna stock program to a $3 chip, or cut the J1 jumper so the ecu uses the stock program located inside of the cpu itself. Free to go back to stock
Old Feb 19, 2003 | 04:08 AM
95gsr's Avatar
we not talking about hondata but if i was to get a hondata would i need a p28 ecu??
what car is the p28 from?
Old Feb 19, 2003 | 07:05 AM
New User
no u could use a p72 w/ hondata. p28 is from sohc civic.
Old Feb 19, 2003 | 12:50 PM
95gsr's Avatar
can i use a p28 chip in a p72?
sorry for dumb questions just trying to get to know what to mess around with
Old Feb 19, 2003 | 12:59 PM
New User
huh?
Old Feb 19, 2003 | 01:12 PM
TimoneX's Avatar
New User
I believe the chips are physically the same but the programs are not due to the presence of another cam and more fuel. SOHC vs DOHC.
Old Feb 19, 2003 | 01:25 PM
95gsr's Avatar
threatcon this is what i was looking for
doesn't hondata software allow me to take a p28 map and change it to a p72?
UberTeg's Avatar
There are some major differences between the p28/p30 program, and the p72 program. You *could* run a p28 program in a p72 ecu, but not vice-versa.
Old Feb 19, 2003 | 02:40 PM
95gsr's Avatar
Default Re: what ecu in 95 gsr??? p 28? (UberTeg)
so if i put a p28 eprom chip into my p72 my car will run without a problem or will i have to convert it to a p72 program
Nikademo
Apr 9, 2010 05:32 PM
aF
Jan 29, 2006 08:39 PM
maxheat
10
Feb 9, 2005 12:55 PM
brbHPR
Mar 13, 2003 09:19 PM
