Will US ITR Header fit 90 teg with B16
Will a USDM Type R header fit a JDM b16 in an 90 integra? or will i need a longer/shorter cat? or some modification?
thanks
need to know asap thanks
thanks
flange angle is most likly different than your factory cat..
THanks for alll the help
i heard that all bseries headers fit the block but when you go to bolt up the end of the header to the cat you have problems. i have a Kamakazie for an ITR on my GSR and I had to get about 2 inches taken out of my exhaust and the fittment of the entire exhaust system is still kinda out of whack.
ok thanks alot i have a high flow cat for a eg also so maybe it'll just work out that it'll fit with that i guess i'll go for it
thanks
thanks
Seedc2
Nov 4, 2004 12:24 PM
