Secondary Fuel Rail Question
its pretty simple to do. Its called staged injection. What you would do is run a smaller set say 550cc off boost for crusicing and on boost a set of 550cc additonal and you are set.
The JG 8 injector manifold is good place to start they come with another rail and fittings.
Most aftermarkety ECUs can control it. Like motec,Haltech,aem etc.
Why mess with the added complexity unless you can't get enough fuel out of 4 injectors. Most people who are doing it are running methanol and have to run 8 injectors. You won't get any performance increase out of using 8 if you don't need to.
