Can extended wheel studs be put on without removing the hub?
Well those bad boys are staying on.
If I were to take everything off (L and R hubs), both sides, what is an "average" time for doing so?
Getting the knuckle off the car is the best way to do it. That takes maybe 15mins (unless you have hell with the lower ball joint)
Then you remove all the remaining brake hardware (another 5mins)
Whack the hub out (2mins)
hammer the old studs out (2mins)
hammer the new ones in (5mins)
whack the hub back in the knuckle/wheel bearing (5mins)
install rest of the crap (20mins)
So, about an hour each side.
Wheel Stud Install
I did it this way... but I removed the knuckle. I think it can be
done like this on the car, but it I think it will be more difficult.
[Modified by WWDTrackRacer, 1:36 AM 2/19/2003]
[Modified by WWDTrackRacer, 1:37 AM 2/19/2003]
damn good link yo...I used 89 integra studs for my EF and they werk great...those arp's are mighty long yo....Ive also heard the knurl on the Arp studs are a lil bigger than the holes in the hub so you have to grind on those too..
Now that i look at the pic of all the studs next to each, other i can see the ARP's splined area IS thicker...wonder why he didnt mention this...hmmmm..no Arp part number either..
[Modified by JOEY F., 7:11 PM 2/19/2003]
ef90b16
Nov 28, 2008 09:36 PM
