What pulley kit is better aem or unorthodox racing
Old Feb 18, 2003 | 12:47 PM
h-spec_crx's Avatar
Default What pulley kit is better aem or unorthodox racing
i have a 01 honda civic ex what would be better for my car aem pulleys or unorthodox pulleys. or what should be my next mod.
Old Feb 18, 2003 | 01:19 PM
631 Teggy's Avatar
Default Re: What pulley kit is better aem or unorthodox racing (black_honda01)
Pulleys are not necissary my friend...
EDIT: Stock pulleys are good...
[Modified by 631 Teggy, 10:19 PM 2/18/2003]
Old Mar 2, 2003 | 12:34 PM
Muckman's Avatar
Moderator in Chief
Default Re: What pulley kit is better aem or unorthodox racing (631 Teggy)
Why? post any good or bad experiences you've had with aftermarket pulley sets.
Old Mar 2, 2003 | 12:51 PM
tony1's Avatar
How do you figure?? All stock stuff is good, right?
Go with the aem pulleys. They are accessory pulleys and won't harm the engine. The unorthodox pulleys remove the harmonic dampner on the crankpulley putting more stress on the oil pump and bearings.
Old Mar 2, 2003 | 02:42 PM
Muckman's Avatar
Moderator in Chief
Default Re: What pulley kit is better aem or unorthodox racing (tony1)
The AEM site is not very clear what the TRU Power Pulley kit includes. Does it include a crank pulley? Do the AEM Pulleys have the problem with the harmonic dampner?
Old Mar 2, 2003 | 02:59 PM
ASHY-ELBOW's Avatar
Default Re: What pulley kit is better aem or unorthodox racing (Muckman)
No crank just one for alternator one for ps and two belts
Old Mar 2, 2003 | 03:11 PM
Kamin's Avatar
Default Re: What pulley kit is better aem or unorthodox racing (ASHY-ELBOW)
waste of money.
Old Mar 2, 2003 | 03:13 PM
tony1's Avatar
Default Re: What pulley kit is better aem or unorthodox racing (Kamin)
If you can get any power at all for $150 out of a honda then it's worth it. The pulleys are one of the few things that actually have a good power:dollar ratio...
Old Mar 2, 2003 | 03:16 PM
turbospool's Avatar
i took out my PS and all i put on was the AEM alternator pulley, and yes i did feel a diff, and no its not in my head.
Old Mar 2, 2003 | 03:17 PM
Civic_95_Si's Avatar
I've had my UR set(Crank,Alt,&PS) for over a year and have had zero problems.
Old Mar 2, 2003 | 03:22 PM
Suprdave's Avatar
Default Re: What pulley kit is better aem or unorthodox racing (Civic_95_Si)
Where can I get an AEM Alternator Pulley ONLY?
Suprdave
Old Mar 2, 2003 | 03:27 PM
tony1's Avatar
Default Re: What pulley kit is better aem or unorthodox racing (Suprdave)
I'm pretty sure we can order the alt. pulley only. Give me a call at the shop and i'll check on it for you...
Old Mar 2, 2003 | 03:43 PM
cvcc's Avatar
I'm using AEM cam gear, AEM alt pulley, and Unorthdox racing crank pulley on my D16Z6 project right now and going w/ a Garrett T3 turbo. No ac or ps. I'm hoping this will be an ok setup since I'm hearing alot of bad stories about crank pulley.
Old Mar 2, 2003 | 03:47 PM
DeepSi's Avatar
Default Re: What pulley kit is better aem or unorthodox racing (cvcc)
Wow, pulleys really make a difference? I was always under the assumption that they made very little difference, and would only use them if you have extra money. I need to look into these then.
Old Mar 2, 2003 | 04:25 PM
Suprdave's Avatar
Default Re: What pulley kit is better aem or unorthodox racing (DeepSi)
They can't hurt, I'm trying to squeeze any power I can get.
Suprdave
Old Mar 2, 2003 | 06:59 PM
turboex's Avatar
ran my complete unorthadox with crank pully for 60,000 miles. no probs yet
Old Mar 2, 2003 | 11:01 PM
accordexchange's Avatar
Default Re: What pulley kit is better aem or unorthodox racing (turboex)
what's the verdict..?
631 Teggy: Pulleys are not necissary my friend...
tony1: Go with the aem pulleys. They are accessory pulleys and won't harm the engine. The unorthodox pulleys remove the harmonic dampner on the crankpulley putting more stress on the oil pump and bearings.
Kamin: waste of money.
turbospool: i took out my PS and all i put on was the AEM alternator pulley, and yes i did feel a diff, and no its not in my head.
Civic_95_Si: I've had my UR set(Crank,Alt,&PS) for over a year and have had zero problems.
turboex: ran my complete unorthadox with crank pully for 60,000 miles. no probs yet
awashousky1
Aug 21, 2007 12:42 PM
GreenMachineRex
13
Apr 26, 2004 12:53 PM
Memo6453
May 8, 2003 08:06 PM
type-si
May 7, 2003 09:31 PM
