Tuning is good...a dyno plot of running an incorrect ecu vs a tuned Hondata
Old Feb 18, 2003 | 12:13 PM
Austin's Avatar
Default Tuning is good...a dyno plot of running an incorrect ecu vs a tuned Hondata
So I recently traded in my Hondata Stage 2 for the newer Hondata S200, I was lucky enough to have DynoSpot Racing work a deal with me. I had Monday off so I decided to make the drive down to visit the shop about picking up the new Hondata unit and about a possibility of a bolt-in 4 point cromoly rollbar. Since I was there I decided to throw the car on the dyno to see what was going on...
Setup is the same for both runs except the ecu:
Comptech icebox and intake
Mugen headgasket
Hondata intake manifold gasket, street setup
Hondata S200
HyTech header and exhaust, test pipe
toda cam gears +5, +5
Prelude '97+ 290cc/min injectors
Red - stock ecu
Blue - tuned Hondata
As you can guess that I was running quite rich with the stock ecu on the car, lots of black smoke.
Full Size edition - cut and paste into your browser:
http://www.imagestation.com/picture/...9.jpg.orig.jpg
[Modified by Austin, 1:13 PM 2/18/2003]
Old Feb 18, 2003 | 12:15 PM
MARC P's Avatar
Default Re: Tuning is good...a dyno plot of running an incorrect ecu vs a tuned Hondata (Austin)
pic not working .
sorry to lazy
[Modified by MARC P, 4:22 PM 2/18/2003]
Old Feb 18, 2003 | 12:17 PM
Chris93Si's Avatar
Wow that's a big difference, how long did you guys spend tuning to notice that much change?
Old Feb 18, 2003 | 12:18 PM
IGGY's Avatar
Good numbers man, now that looks like where your car should be.
JDMb18civic's Avatar
Default Re: Tuning is good...a dyno plot of running an incorrect ecu vs a tuned Hondata (MARC P)
nice and smooth...
[Modified by JDMb18civic, 9:19 PM 2/18/2003]
IGGY's Avatar
pics not working
cut and paste the link.... Lazy!
Old Feb 18, 2003 | 12:19 PM
Mires's Avatar
Damn, that is a big jump. Nice work!
Old Feb 18, 2003 | 12:23 PM
MARC P's Avatar
what cams and comp
Aaron M's Avatar
Default Re: Tuning is good...a dyno plot of running an incorrect ecu vs a tuned Hondata (ITR-862)
very impressive
Old Feb 18, 2003 | 12:28 PM
TheHeyta
Guest
Posts: n/a
Default Re: Tuning is good...a dyno plot of running an incorrect ecu vs a tuned Hondata (SilverB18C1)
hela nice numbers.
Old Feb 18, 2003 | 12:31 PM
Young_R's Avatar
Default Re: Tuning is good...a dyno plot of running an incorrect ecu vs a tuned Hondata (SportInjected)
that is very very nice.
Old Feb 18, 2003 | 12:37 PM
Shark Tank's Avatar
Default Re: Tuning is good...a dyno plot of running an incorrect ecu vs a tuned Hondata (Young_R)
is there really a huge difference in the stage 2 versus the s200 hondata systems?
Old Feb 18, 2003 | 12:38 PM
EK MONEY's Avatar
Default Re: Tuning is good...a dyno plot of running an incorrect ecu vs a tuned Hondata (CART fan)
good lookin power curve...
Old Feb 18, 2003 | 12:40 PM
Rob :190:'s Avatar
what cams and comp
AFAIK, stock ITR and whatever the mugen hg gives, 11:1 i think
Old Feb 18, 2003 | 01:16 PM
StinkyTofu's Avatar
Default Re: Tuning is good...a dyno plot of running an incorrect ecu vs a tuned Hondata (Rob :190:)
Wow, thats very impressive. I can't wait to get my car s200 tuned. How long did you guys spend on the dyno?
Old Feb 18, 2003 | 01:20 PM
jdmspoonitr's Avatar
Default Re: Tuning is good...a dyno plot of running an incorrect ecu vs a tuned Hondata (StinkyTofu)
great numbers austin. congrats to you and dsr. Hopefully I can get mine back down to dsr soon to fine tune the new goods that are coming in.
Old Feb 18, 2003 | 01:46 PM
Austin's Avatar
Default Re: Tuning is good...a dyno plot of running an incorrect ecu vs a tuned Hondata (Chris93Si)
The reason why the gain appears so large is becuase I was running really rich with the 290cc/min injectors installed while running off the stock ecu.
It was initially a 1-1.5 hour tuning session...I was only there for the new S200 and since the dyno was open decided to hop on to see how well the car was holding up.
There were no changes from the initial tuning that was done back in November(I think).
The S200 gives you the ability to have vtec turn on via map signal and rpm vs just rpm as in the Stage 2-4, as well as air conditioning cutoff, cold idle fueling, and a few others like some sensors can be disabled, the majority of the gains are for the tuners as there are a lot of changes and benefits for them...I just wanted it for the load based vtec and the air conditioning cutoff.
Austin
Old Feb 18, 2003 | 01:48 PM
itr1244's Avatar
That's some mad gain right there man
good for u
Old Feb 18, 2003 | 01:50 PM
obd2gsr's Avatar
well, that does it. you've convinced me. i was trying to hold out on it, but i guess i'm going to have to call up lawrence and get hondata s200. great numbers!
Old Feb 18, 2003 | 01:51 PM
ill phil's Avatar
Default Re: Tuning is good...a dyno plot of running an incorrect ecu vs a tuned Hondata (itr1244)
Very impressive numbers and gain from the Hondata.
Old Feb 18, 2003 | 02:15 PM
DarthLuder's Avatar
New User
Default Re: Tuning is good...a dyno plot of running an incorrect ecu vs a tuned Hondata (ill phil)
Old Feb 18, 2003 | 04:04 PM
mafay2's Avatar
New User
Nice!!
Looked like the 1.5 hrs of dyno tune is your best mod!!
NoVtecLs
Oct 6, 2004 05:54 PM
sixcylinders
Sep 21, 2004 06:03 AM
Agamemnon
Oct 10, 2001 04:10 PM
