miss at idle
Old Feb 18, 2003 | 09:33 AM
blackrex91's Avatar
Default miss at idle
i have a 91 crx dx. i have a crane cam(idle-6800), dc sports header, custom cat-back to a 5zigen muffler, full msd ignition, aem adjustable cam gear(set at zero), sneaky pete nitrous system, and air intake. The problem is at idle it has a miss to it. Sometimes it does it sometimes it doesnt. I want to fix this before i do the mpfi swap. Any ideas?
Old Feb 18, 2003 | 11:29 AM
AbaZ's Avatar
Default Re: miss at idle (blackrex91)
the larger duartion/lift of the cam will make it lope a bit at idle... I would do a compression test just to make sure its ok. You also might not have a valve sealing good in your head.
Jeff
tommypilot
13
Apr 12, 2013 05:02 PM
MayDayTegGS
Aug 27, 2012 06:56 PM
superslowcrx
Jan 30, 2006 12:25 PM
crx90rcr
Apr 26, 2005 08:16 PM
94civicx
Jan 1, 2002 09:26 AM
