Fuel delivery question on a built turbo'd ZC
ok, my Zc is almost ready to be put together and dropped in my car, i'm tryin to figure out my fuel situation. I have really no experience with this so i'd appreciate some informative feedback. Ok as for my setup i have a t3/t4, the motor will be boosted at about 15-20 psi, i'll probably go with 550 injectors and i have a walbro 255 i believe fuel pump. I'm not sure if i'm gonna run Hondata or Zdyne if that makes a difference. I'd like to know if i need a FMU or fuel pressure regulator or anything i may be possibly forgetting. Any info would be greatly appreciated. Thanks
Guest
Posts: n/a
if you are going to be using a fuel management system then you will not need the fmu and the fuel pressure regulator... use the stock regulator....good luck with the set up... happy boostin
Just go with a high volume intank fuel pump. You may need to go with larger injectors then the 550's.
injectors, pump, and engine managment is what you'll need.
bmoser18
Aug 16, 2005 02:30 PM
