b16 obd0 and 0bd1 question
i'm getting a b16 for my crx, and i've already converted my car to obd1. will a obd1 b16 distributor fit the sir1 b16? if not what obd1 dist will fit it? any other probs i'll run into trying to put the obd0 motor into a obd1 car?
You can run your OBD0 injectors just as long you are still using the injector resistor box. Otherwise you just need to re-pin your ECU (or get the harness from Jason-90BlownHatch on H-T)
Wire Vtec, vtec oil pressure, knock, and 4-wire O2.
You will also need to convert and repin the 2 plugs on your distributor.
no need to repin, or run resistor box...i'm already obd1. i just didn't wanna have to buy a sir2 long block, and a seperate tranny. just wanted to know it the dizzy would fit...i already know everything else that needs to be done...thanks for the info
crazyef8
10
Apr 20, 2009 09:44 PM
RA122324
Jun 17, 2005 04:02 PM
