What hondata? Which to get?
Guest
Posts: n/a
I have an 1997 obdII Ls integra with a drag gen 3 kit on it. I am needing to go to hondata for reasons not being revealed right now. (its getting a massage)
Anyone know what hondata system I need to run?
I can get a P28 socketed supposivley for a stage 2/3/4/s100/s200 series hondata
and the harness for obd2 to obd1.
Is that what I need or do I need a different socketed ecu?
If you're not goign to do the tuning yourself and the s100 with boost will be fine for you.
Let me know if you need it. I got it at a good price.
The p28 that is already socketed should be good.
HTH
HTH
T, the S200 will allow you to pick up a wideband O2, ROM editor, and some other toys and let you autotune your car when ever you want. Personally, I won't be putting new pistons in the car every month or changing out cams constantly, so I'm going to sit with the S100 on a P28. I just can't afford the S200 right now. I don't know your cash flow right now, but if you can get the S200 do it. Then you can tune the rest of our cars on the street. That way we don't have to go to the dyno and drop $300 everytime a new mod gets put on the cars. BTW, I can get P28s for $100-$120 depending on condition.
s200 isn't that much more than a s100 so i would just fork over the 50 or so extra bucks and get that.
[Modified by yellowsub, 11:39 AM 2/18/2003]
minimal $ difference.
I think you can do that. http://www.hondata.com/ check out the site to be sure.
I have a 98 ls
So how much are we looking at for everything needed
I'm looking to replace my Safc fuel system real soon
Hondata s200 $$ ?
OBDII to OBDI harness connector $$?
p28 socketed for s200 $?
is this all i need?
someone please PM me
i have a 98 integra ls t3t4
Hondata s200 $$ ?
is this all i need?
nikko_SOHC
Jul 5, 2006 04:24 AM
---with the exception of a harness.
