Tail lights gaskets for 94-01 Integra
Old Feb 18, 2003 | 04:15 AM
vtec95's Avatar
Default Tail lights gaskets for 94-01 Integra
Who is the guy on here that sells those gaskets for the 94-01 tails? I need a pair. There better than stock i guess. Thanks.
Old Feb 18, 2003 | 04:46 AM
Eva01's Avatar
Default Re: Tail lights gaskets for 94-01 Integra (vtec95)
I would just stick with OEM parts. I cant see how an aftermarket gasket would be better than OEM.
Just go to the dealer or online from acuraautomotiveparts.org.
Old Feb 18, 2003 | 06:23 AM
ragejed's Avatar
Default Re: Tail lights gaskets for 94-01 Integra (Eva01)
I make em
If you wanna pay 27 bux for oem, you go right ahead, lol
BTW: Aftermarket can be better then oem
[Modified by ragejed, 7:23 AM 2/18/2003]
Old Feb 18, 2003 | 06:30 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Tail lights gaskets for 94-01 Integra (ragejed)
I made my own set following ragejed's methods... they are thicker than stock but that makes the taillights stick out slightly. I used 2 layers of 3mm foam for a 6mm gasket, which may be too thick, but hey it stopped my trunk leaking.
Old Feb 18, 2003 | 06:31 AM
ragejed's Avatar
Default Re: Tail lights gaskets for 94-01 Integra (PatrickGSR94)
ya, I make mine same width as stock ones now
Old Feb 18, 2003 | 07:04 AM
Eva01's Avatar
I make em
Just curious...How do you make them? Do you have a thread outlining the details?
All I found was this in your archived threads: fixing water in tailights
Old Feb 18, 2003 | 07:05 AM
ragejed's Avatar
Check my sig
Old Feb 18, 2003 | 07:06 AM
Eva01's Avatar
Check my sig
DUH!! Thanks!
Old Feb 18, 2003 | 09:43 AM
ragejed's Avatar
Default Re: Tail lights gaskets for 94-01 Integra (krrrrrrzyrebel)
it prevent moisture in the taillight..and in the trunk
Old Feb 18, 2003 | 09:50 AM
Chris's Avatar
without that gasket, water will enter the light housing (if alot, short out and corode the lights). You will get water in the trunk area, causing mold, mildew and a NASTY smell if left for any amount of time.
Not to mention the windows will always be all fogged up and harder to clear due to all the moisture in the cabin.
Old Feb 18, 2003 | 10:04 AM
d8168055's Avatar
Default Re: Tail lights gaskets for 94-01 Integra (Chris)
what material do u use to make them?
tC_Dragon's Avatar
damn its amazing what a little piece of foam can do huh?
Old Feb 18, 2003 | 10:09 AM
ragejed's Avatar
Default Re: Tail lights gaskets for 94-01 Integra (d8168055)
Check my sig
Old Feb 18, 2003 | 12:33 PM
Community Builder
Yeah my rear glass always got fogged up really bad on the inside, plus I had small puddles in the trunk, causing corrosion on all my jack tools, jack, etc.
Made new gaskets and all is well.
Only problem with mine is I couldn't find any foam stuff longer than 18" (Integra taillight gaskets are about 20" long), so I had to splice two pieces end to end (the splice on each layer of foam is offset from each other so it becomes like a solid piece).
Old Feb 18, 2003 | 12:51 PM
Eva01's Avatar
My tail lights were fogged up but I fixed it w/out changing the gasket. I just removed the light assembly, dried it with a hair dryer and put a dab of gasket maker into the one hole on the top toward the rear quater panel side of the car. Fixed the problem and been water free for about a year.
Old Feb 18, 2003 | 02:19 PM
ragejed's Avatar
Ya, this is why I make them and sell em
Its hard to find the material. I had to find a wholesale company to sell me in bulk, wasent easy.
Old Feb 18, 2003 | 02:45 PM
b18C1_liLkyLe's Avatar
i.ve just noticed the same prolem on the reverse light part of the passenger side rear tail-light...****.
Old Feb 19, 2003 | 02:06 PM
AK94GSR's Avatar
yeah, i ordered mine ragejed. they work great, but yeah the taillight does stick out a bit, but hey thats better than the nice pool that my trunk used to have.
Old Feb 19, 2003 | 02:16 PM
ragejed's Avatar
Default Re: Tail lights gaskets for 94-01 Integra (AK94GSR)
Ya, I did a revision of the gasket
Mine are now as thick as stock ones.
Glad u like tho
[Modified by ragejed, 3:16 PM 2/19/2003]
Old Feb 19, 2003 | 02:21 PM
SMZ GSR's Avatar
hey man, are the ones you sent me the new style you do??
i'm putting them in this weekend when i do my s2k antenna
Old Feb 19, 2003 | 02:25 PM
ragejed's Avatar
Default Re: Tail lights gaskets for 94-01 Integra (SMZ GSR)
Yup, you got the new ones. Let me know how they fit!. If they still stick out too much (which they shouldnt) ill make them 1 more mm thinner.
Old Feb 19, 2003 | 06:07 PM
reno96teg's Avatar
this makes me want to check my gaskets..
1984eghatch
Nov 13, 2012 10:17 PM
fryman
Apr 30, 2008 06:27 PM
o0oz
Apr 9, 2007 10:12 AM
