. clutch question
Old Feb 18, 2003 | 12:27 AM
AzntaggeR's Avatar
TSPeed Factory
Default . clutch question
ok, heres the problem. the throwout bearing in my clutch assembly is bad. it makes a loud rattling noise (especially in 1st and 2nd gear). what i need an opinion on is: is it worth it to take out the clutch and replace just the throwout bearing? because others have told me if i'm going to replace the throwout bearing i might as well replace the clutch too, but i don't want to have to put a new clutch in if the one i already have is fine
and what are the worst things that can happen by not replacing a bad throwout bearing?
Old Feb 18, 2003 | 05:28 AM
hatchdrvr's Avatar
Default Re: . clutch question (AzntaggeR)
It is always recommended to replace the throwout bearing when you replace the clutch. As far as not replacing it when it goes bad, you need to do that ASAP or you won't have much of a tranny left because when bearing go bad they generate alot of heat because they don't spin freely and also tend to break apart into pieces. so you definitely don't want jagged pieces of metal floating around in your tranny.
Old Feb 18, 2003 | 07:21 AM
Shawn C's Avatar
In The Garage
Default Re: . clutch question (hatchdrvr)
^---- what he said. pull the tranny, replace the throw-out bearing, clutch, pressure plate, pilot bearing, and resurface the flywheel. it'll be worth the 150-200 bucks or so.
Old Feb 18, 2003 | 07:57 AM
AzntaggeR's Avatar
TSPeed Factory
yea i get what ur say, but is it worth it to go thru all that time to pull the tranny out just to replace the throwout bearing?
Old Feb 18, 2003 | 09:28 AM
Shawn C's Avatar
In The Garage
definitely. you will end up replacing the whole tranny if that thing flies apart. the throwout bearing is pretty big
Old Feb 18, 2003 | 05:16 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: . clutch question (22lbGS-R)
bump
i need more info
Old Feb 18, 2003 | 06:01 PM
Shawn C's Avatar
In The Garage
do you know what the throwout bearing is/does/looks like?? how do you know its the TOB?
hcs1jimmy
Apr 19, 2011 04:12 PM
vlc92189
Jul 23, 2006 05:01 PM
maxogsr
Jun 22, 2005 06:46 PM
doublejz
Mar 9, 2004 01:19 PM
mr_mbuna
Dec 4, 2002 04:04 AM
