ES motor mount topic
Old Feb 17, 2003 | 11:50 PM
GRHatchMan's Avatar
Default ES motor mount topic
I'm swapping soon and I am already buying Place Racing poly stock replacement mounts for driver's side, tranny side, and rear. The Energy Suspension m.m. inserts usually only come in kit form, and from what I remember they are for the right and left front lower mounts and the rear, correct? Should I bother with replacing the front two, or will it be overkill and make my car vibrate like a ****?
Here is a diagram:
Would the inserts be for #8, 9, and 3? Thanks
[Modified by GRHatchMan, 8:53 AM 2/18/2003]
[Modified by GRHatchMan, 8:54 AM 2/18/2003]
Old Feb 18, 2003 | 12:08 AM
97hb's Avatar
Default Re: ES motor mount topic (GRHatchMan)
they are for the right and left front lower mounts and the rear, correct? Would the inserts be for #8, 9, and 3?
You are correct mang . I got all three and it vibrates alittle, but not like people make it out to be.
Old Feb 18, 2003 | 12:16 AM
ill phil's Avatar
Default Re: ES motor mount topic (97hb)
Word. It's not near as bad as people make it out to be
Old Feb 18, 2003 | 08:10 AM
GRHatchMan's Avatar
Default Re: ES motor mount topic (ill phil)
Thanks guys.
Old Feb 18, 2003 | 08:24 AM
NonovUrbizniz's Avatar
Loved
OH I'd have to disagree on that one... I've only had them in for a couple weeks or so and it's GREAT when your on the throttle but my idle is REDICULOUS. I have to shut of my car at the drive through or if I'm waiting for someone that or I have to rev the engine up to 1-1.5k otherwise it's ruff as hell.
My front driver side was shot on one side though so I'm gunna replace it with a stocker and put the inserts back in on the new on and see how it is.
Old Feb 18, 2003 | 09:00 AM
Bumnah's Avatar
Default Re: ES motor mount topic (NonovUrbizniz)
I've been running polyurethane mounts. I've noticed significant vibration, but i'm completely gutted. Make sure you put the rear mount in. That's the most important mount (I'd say). I'd also would recommend NOT buying the Place racing mounts. I used a place racing mount on my friend auto to manual conversion, I was not impressed to say the least. HASport is what I just ordered. The billet aluminum with the drag rear mount. $375 for the 3 mounts whole thing from a local shop. I'm running the ES front insert for the front lower mounts. Check with Prothane to see if they make inserts for those front two mounts. Prothane stuff is much stiffer from what I've noticed and I like their quality better. I'm running ES, but I'd rather have prothane. They didn't make the inserts last time I contacted them that's why I'm running ES front lower inserts.
Stay away from Place racing though. I'm not a fan of their products at all.
[Modified by Bumnah, 1:02 PM 2/18/2003]
Old Feb 18, 2003 | 09:03 AM
JV's Avatar
JV
Who?
Default Re: ES motor mount topic (Bumnah)
The vibration is not too bad. Just alittle rough at idle...
Old Mar 1, 2003 | 11:05 AM
Loved
Default Re: ES motor mount topic (JV)
Update.... it's not as bad as it was... I still occasionally turn my car off when I'm gunna be sitting for a while... and my pregnant wife HATES THEM. but it's not that bad.
Black R
Apr 2, 2011 08:59 AM
TypeRuz
Feb 7, 2004 10:04 PM
jason_alt
Mar 21, 2003 10:32 PM
migs
Feb 5, 2003 08:25 PM
HKxBlur
Dec 27, 2001 10:00 AM
