non obd B16 Q's
Old Feb 17, 2003 | 07:58 PM
EF_LSVtec's Avatar
Default non obd B16 Q's
My 1st gen distributor is going out and I heard that a 91 LS distributor will work too but need to cut off 2 of the mounts to fit. I can have mine cut or can I just take the 91 LS distributor internals and put it in the B16? How difficult is this to do?
Old Feb 17, 2003 | 08:12 PM
raene's Avatar
Default Re: non obd B16 Q's (EF_LSVtec)
Yes you can just swap internals... so I hear. Unfortunately I couldn't tell you how hard it would be to do. I think it's a better route, however tough it is, than ghetto-rigging the wrong distributor shape for the task.
Old Feb 17, 2003 | 08:13 PM
EF_LSVtec's Avatar
Default Re: non obd B16 Q's (raene)
good enough...I guess I'll soon find out...thanks.
Old Feb 17, 2003 | 08:29 PM
customx_'s Avatar
New User
internals from 88-91 cibic/crx or 90-93 integ will fit in jdm b16 dizzy. trust me, my jdm dizzy went out and i replaced it with all new internals from integ. works fine now. just make sure you get oem parts. dont know about using a 90-93 dist but you can always get the jdm dist rebuild. i think its like $150 w/warranty, price a used jdm b16 dist anyways.
Old Feb 17, 2003 | 08:31 PM
EF_LSVtec's Avatar
Default Re: non obd B16 Q's (Agent_Smith)
Even better...thanks for the added support.
Old Feb 17, 2003 | 08:34 PM
civicdragger818's Avatar
I used a D16a6 dizzy on my b16a1 head and I only had to cut one of the ears off. I got 2 of the three to line up. Leaks little to no oil. Im satisfied I guess for now.
Old Feb 17, 2003 | 08:57 PM
crx8psi's Avatar
Default Re: non obd B16 Q's (civicdragger818)
I also used a d16a6 distributor and cut one of the legs off and it works fine, for now anyways till i get another one .
Old Feb 18, 2003 | 06:15 AM
EF_LSVtec's Avatar
Default Re: non obd B16 Q's (b16a88hatch)
D16a6, is that from a 90-91 Si?
Old Feb 18, 2003 | 06:37 AM
ricodemus's Avatar
yes. Maybe even 88-91?
bhigh
Feb 13, 2009 07:01 PM
sanjiyan69
May 30, 2004 06:14 PM
ZERO COOL
Mar 9, 2003 07:50 PM
out2wincrx
Jun 9, 2002 07:41 PM
