what axsles do i use?
Your HF axles will be fine. The difference lies in the outer joint. The HF/STD have a smaller (23 spline) outer joint while the Si/DX has the larger (26 spline) outer joint. The inner joints are the same so the HF axles will work with an Si tranny as long as you are keeping your HF hubs.
If you are plan on doing a B16a swap in the future, or you are planing on running a ZC tranny with your D-series, you will need to replace the HF hub to a SI/DX hub. (larger) hit up the wreckers for complete knuckles.
Jeff
Jeff
1988 hf crx trans si, dx, hf splines the same for the axles into the hub and trans, i know the 89+ c
80 dolla crx hf
Jun 9, 2008 03:03 AM
xparalandrax
18
Mar 10, 2007 10:57 AM
project dc2
Aug 5, 2003 05:57 PM
pdiddyparsons
Feb 20, 2003 01:04 PM
