Lighting problems
Old Feb 17, 2003 | 07:20 PM
wutupnut's Avatar
Default Lighting problems
I posted a topic about this a couple days ago, but cannt seem to find it now.. Anyways i went to change my back up lights, when i put 1 in everything was fine, but when i put the other in my back up lights stopped working as did my tach, clock, blinkers, tail lights, fuel gauge, temp gauge.. I checked the fuses and they all seemed fine, any idea's?
Thanks again...
Old Feb 17, 2003 | 08:46 PM
CRX Si's Avatar
Default Re: Lighting problems (wutupnut)
check your grounds... that seems to be an answer for everything...
Old Feb 17, 2003 | 09:52 PM
xcathodex's Avatar
Default Re: Lighting problems (CRX Si)
my old '88 rex did the same thing, the taillights stopped working and i was never able to find a short or any kind of electrical fault. bulbs were fine, fuses were fine.
Old Feb 17, 2003 | 09:54 PM
Louie B.'s Avatar
I hate to point out the obvious, but did you check all the fuses under the hood? also, how did you check them? With a meter (or test light) or just visual inspection? (just because a fuse "looks" good doesn't mean it is)
That many things going at once seems like a main fuse (one of the big-uns under the hood) to me.
Old Feb 18, 2003 | 06:00 AM
wutupnut's Avatar
Default Re: Lighting problems (thumpu77)
I just checked all the fuses by looking at them, i'll break out the test light this afternoon and get back to ya... Thanks
Old Feb 18, 2003 | 06:53 PM
Crazy_Cracka's Avatar
Well i replaced alllllll the fuses, and i guess that wasnt the problem, didnt help anything anyways.. I was messing around by the tail lights, and i took the cover off that hides the back up lights, and i noticed a wire that was grounded to the car, but the other end wasnt connected to anything, could that be the problem? Anyone know where it connects?
Old Feb 18, 2003 | 06:58 PM
sporkcrx's Avatar
Default Re: Lighting problems (Crazy_Cracka)
If it looks like it's grounded there with a bolt, then it's suppossed to be there. But if it's a wire that's been rubbed of it's protective covering, and hitting bare metal, just put some electrical tape over it.
Old Feb 18, 2003 | 07:02 PM
Default Re: Lighting problems (sporkcrx)
Sorry bout this but i'm on my brother's user name, but anyways, one end of the wire is connect with a bolt, but the other end is loose, any idea where it is suppose to connect?
Old Feb 18, 2003 | 07:44 PM
Louie B.'s Avatar
are you working on a CRX, Hatch, or 4-door?
a disconected ground like the one you're describing could be the cause of taillights not working, but not things like clock, etc like you were describing above.
when you went through your fuses, did you check the 3 main fuses? the 3 big ones circled in the pic below? that many things dying at once makes me think it's one of these....
Old Feb 19, 2003 | 07:13 AM
Anyone know where i can get replacement main fuses like that?
Old Feb 19, 2003 | 08:27 AM
Louie B.'s Avatar
just about any auto parts store should have them, they're not all that cheap, so test the ones you have first.
Bernard
Sep 4, 2007 10:48 PM
Tenacious T
Honda Motorcycles
Jun 17, 2007 05:20 PM
Rayog21
Sep 21, 2005 08:38 PM
DarkBB4
Oct 2, 2004 01:04 PM
guy_that_owns_3_Rex's
May 11, 2004 01:53 PM
