JDM CTR Pistons In USDM 00' B16A
Old Feb 17, 2003 | 07:11 PM
The G2 Racer's Avatar
Default JDM CTR Pistons In USDM 00' B16A
I'm gonna swap out the stock pistons for CTR ones.
What will the compression ratio go up to?
Do I need to change my piston rings? What ones should I use?
Shot Peen my stock rods?
Use after market rod bolts?
Could I use .25mm oversize?
Thanks in advantace.
Old Feb 17, 2003 | 07:40 PM
dfoxengr's Avatar
Default Re: JDM CTR Pistons In USDM 00' B16A (The G2 Racer)
i wanna say about (EDIT 11:1) because LS/vtec though longer stroke...is 12.4 with b16 head and CTR pistons..
should change rings, stocks are OK
shot peen them if ur building the motor more
dont have to use AM bolts
and can go 25 over if u bore the block 25 over..
[Modified by hybridvteceg, 12:12 AM 2/18/2003]
Old Feb 17, 2003 | 08:04 PM
TREVER's Avatar
ctr pistons almost make 11 to 1
Sean @ ESG
26
Jan 8, 2007 11:17 AM
Eaglekper0046
Aug 3, 2005 07:18 PM
KoRE
Mar 3, 2003 01:04 PM
myNAteq
Oct 26, 2001 11:07 AM
jdmb16acivic
May 31, 2001 05:23 PM
